<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Surface viewer]]></title><description><![CDATA[<p dir="auto">I wish to view the fields on one of the surfaces in my LF-Magneto Quasi-Static model but cannot see how to specify the surface which I am interested in. Please can you advise?</p>
]]></description><link>https://forum.zmt.swiss/topic/110/surface-viewer</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 08:30:07 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/110.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Dec 2018 08:49:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Surface viewer on Sat, 22 Dec 2018 17:26:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sylvain">@<bdi>Sylvain</bdi></a></p>
<p dir="auto">Thank you, I think that has solved my problem</p>
]]></description><link>https://forum.zmt.swiss/post/306</link><guid isPermaLink="true">https://forum.zmt.swiss/post/306</guid><dc:creator><![CDATA[MagneticProf]]></dc:creator><pubDate>Sat, 22 Dec 2018 17:26:13 GMT</pubDate></item><item><title><![CDATA[Reply to Surface viewer on Wed, 19 Dec 2018 15:02:11 GMT]]></title><description><![CDATA[<p dir="auto">You could perhaps try to interpolate the fields onto the surfaces of interest. To do that, you need to drag &amp; drop the surface (from the Multi-Tree) into the Explorer tree, while in the Analysis tab. This will create a surface object for analysis purposes, with settings such at mesh discretization (minimum edge length).<br />
To perform the interpolation itself, select <em>both</em> (using the CTRL key) the E field (say) and the Surface, then click <em>Interpolate Field</em> in the ribbon.</p>
]]></description><link>https://forum.zmt.swiss/post/300</link><guid isPermaLink="true">https://forum.zmt.swiss/post/300</guid><dc:creator><![CDATA[Sylvain]]></dc:creator><pubDate>Wed, 19 Dec 2018 15:02:11 GMT</pubDate></item></channel></rss>
