<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Export SAR to matlab for analysis]]></title><description><![CDATA[<p dir="auto">Hello everyone. I am a total beginner to Matlab and thus I don't know how to export the SAR results to matlab for post-processing. I searched on the internet but couldn't understand how it works and if it's only done by writing a script or through the matlab importing options. Could someone help me with some tips on how to do so? I need some help to get started and I hope that I will be able to sort it out afterwards and do the analysis myself.</p>
]]></description><link>https://forum.zmt.swiss/topic/141/export-sar-to-matlab-for-analysis</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 11:49:21 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/141.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Apr 2019 10:23:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Export SAR to matlab for analysis on Sun, 20 Feb 2022 05:41:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sayimgokyar" aria-label="Profile: sayimgokyar">@<bdi>sayimgokyar</bdi></a><br />
Note to myself:<br />
Press right-click on fields on output window and "refresh" button after setting up everything.</p>
]]></description><link>https://forum.zmt.swiss/post/1308</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1308</guid><dc:creator><![CDATA[sayimgokyar]]></dc:creator><pubDate>Sun, 20 Feb 2022 05:41:29 GMT</pubDate></item><item><title><![CDATA[Reply to Export SAR to matlab for analysis on Thu, 27 Feb 2020 21:30:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/habib" aria-label="Profile: Habib">@<bdi>Habib</bdi></a> said in <a href="/post/408">Export SAR to matlab for analysis</a>:</p>
<blockquote>
<p dir="auto">then select MATLAB</p>
</blockquote>
<p dir="auto">Hi,<br />
I have a similar problem. In the analysis tab, when I right clicked onto a result to export, I only have one option, Touchstone (R) File Exporter. And it is not exporting anything to anywhere. Does this mean that I do not have the necessary license or something else?</p>
<p dir="auto">BTW: to export a result, I have to open it in plot viewer and export it to csv file by using right click on the plot, which is obviously not the best way to export a result. I would like to learn a better way of doing that. Thanks.</p>
]]></description><link>https://forum.zmt.swiss/post/584</link><guid isPermaLink="true">https://forum.zmt.swiss/post/584</guid><dc:creator><![CDATA[sayimgokyar]]></dc:creator><pubDate>Thu, 27 Feb 2020 21:30:11 GMT</pubDate></item><item><title><![CDATA[Reply to Export SAR to matlab for analysis on Tue, 16 Apr 2019 11:13:32 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much for your help!</p>
]]></description><link>https://forum.zmt.swiss/post/409</link><guid isPermaLink="true">https://forum.zmt.swiss/post/409</guid><dc:creator><![CDATA[gkarathy]]></dc:creator><pubDate>Tue, 16 Apr 2019 11:13:32 GMT</pubDate></item><item><title><![CDATA[Reply to Export SAR to matlab for analysis on Mon, 15 Apr 2019 06:19:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">We can help you with the export of field data (SAR or other fields) form Sim4Life into MATLAB container file.</p>
<p dir="auto">In Sim4Life. you can right-click the SAR quantity in the Output window, select Import/Export, then select MATLAB. This will create an exporter in the analysis pipeline. In the Properties of the exporter, you can define the destination file name and click Refresh.</p>
<p dir="auto">The generated file can be loaded in MATLAB, it contains the grid information and the 3D field data.</p>
]]></description><link>https://forum.zmt.swiss/post/408</link><guid isPermaLink="true">https://forum.zmt.swiss/post/408</guid><dc:creator><![CDATA[Habib]]></dc:creator><pubDate>Mon, 15 Apr 2019 06:19:58 GMT</pubDate></item></channel></rss>
