<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Max modulation tool logic]]></title><description><![CDATA[<p dir="auto">How does the <strong><em>Max Modulation</em></strong> tool calculate the maximum modulation of two electric fields? I am asking since it is not described in the manual and it also does not appear in any of the tutorials.<br />
Based on the <a href="https://zmt.swiss/news-and-events/news/sim4life/sim4life-new-release-v4-4/" rel="nofollow ugc">this</a> post, the tool is based on the formula derived in the <a href="https://www.ncbi.nlm.nih.gov/pmc/articles/PMC5520675/#sec4.4.8" rel="nofollow ugc">Grossman et al., 2017</a> paper which is the following:</p>
<p dir="auto"><img src="/assets/uploads/files/1581328907608-render.png" alt="render.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I applied this formula and the results I got were not correct when post-processing the two electric fields in Python, outside of Sim4Life. The above formula is for the |<strong>E_1</strong>| &gt; |<strong>E_2</strong>| area. The code that I am using in Python is:</p>
<pre><code class="language-python">import numpy as np
import scipy.io as io
base_data = io.loadmat('Directory of extracted mat file for the simulation 1')
delta_data = io.loadmat('Directory of extracted mat file for the simulation 2')
e_field_1 = np.nan_to_num(base_data['EM_E_x_y_z_f0_Snapshot0'])
e_field_2 = np.nan_to_num(delta_data['EM_E_x_y_z_f0_Snapshot0'])
# Calculate the subtraction and addtion of the vectors
E_plus = np.add(e_field_1, e_field_2) # Create the sum of the E fields
E_minus = np.subtract(e_field_1, e_field_2) # Create the difference of the E fields
# Calculate the angles between the two fields for each vector
# Assuming that E_a is the difference of the vectors
dot_angle = np.einsum('ij,ij-&gt;i', e_field_1, E_minus)
cross_angle = np.linalg.norm(np.cross(e_field_1, E_minus), axis=1)
angles = np.arctan2(cross_angle, dot_angle)
# Condition to have two times the E2 field amplitude
max_condition = np.linalg.norm(e_field_2, axis=1) &lt; np.linalg.norm(e_field_1, axis=1)*np.cos(angles)
e1_gr_e2 = np.where(np.linalg.norm(e_field_1, axis=1) &gt; np.linalg.norm(e_field_2, axis=1), max_condition, False)
# Calculate the maximum envelope
envelope = np.where(e1_gr_e2, 2.0*np.linalg.norm(e_field_2, axis=1), envelope)
# Find the other points where the condition is not true
tmp = np.logical_xor(e1_gr_e2, np.linalg.norm(e_field_1, axis=1) &gt; np.linalg.norm(e_field_2, axis=1))
envelope = np.where(tmp, 2.0*(np.linalg.norm(np.cross(e_field_2, E_minus), axis=1)/np.linalg.norm(E_minus, axis=1)), envelope)
np.nan_to_num(envelope)
</code></pre>
<p dir="auto">The resulting graphs can be seen in the figure below, with the calculations from the above code shown on the left-most image, results from Sim4Life shown in the middle and the common points between Sim4Life and Python calculations shown in the right-most image.</p>
<p dir="auto"><img src="/assets/uploads/files/1581327146285-simandclalc2.png" alt="SimAndClalc2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I have tried many variations of the code, setting the amplitudes of electric field on and two to double the value for all points and trying to find the common points and also tried different variations with the indices in the cross product formula. Still with all the variations I could not get all the points filled in the common points plot. The image with all calculated common points is shown below. The correct simulation image is also shown below.</p>
<p dir="auto"><img src="/assets/uploads/files/1581329173415-sec_req.png" alt="Sec_req.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.zmt.swiss/topic/204/max-modulation-tool-logic</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 13:11:22 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/204.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Feb 2020 08:42:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Max modulation tool logic on Wed, 20 May 2020 07:08:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot for sharing your solution!</p>
]]></description><link>https://forum.zmt.swiss/post/683</link><guid isPermaLink="true">https://forum.zmt.swiss/post/683</guid><dc:creator><![CDATA[Sylvain]]></dc:creator><pubDate>Wed, 20 May 2020 07:08:06 GMT</pubDate></item><item><title><![CDATA[Reply to Max modulation tool logic on Mon, 18 May 2020 18:18:51 GMT]]></title><description><![CDATA[<p dir="auto">Well.... after long time finally the solution has been found! Based on the <a href="https://www.biorxiv.org/content/10.1101/602102v2.full" rel="nofollow ugc">Rampersad et al. 2019</a> where the mathematics behind the tTIS is better explained, the key line is that any of the two fields has to change direction whenever the angle between the two vectors is not less than 90 degrees. That was the magic line! Below I post the fully functional code as a python function. The arguments <code>e_field_1</code> and <code>e_field_2</code> are <code>n, 3</code> arrays of the electric fields as produced by Sim4Life.</p>
<pre><code class="language-python">def modulation_envelope(e_field_1, e_field_2, dir_vector=None):
    if dir_vector is None:
        envelope = np.zeros(e_field_1.shape[0])
        dot_angle = np.einsum('ij,ij-&gt;i', e_field_1, e_field_2)
        cross_angle = np.linalg.norm(np.cross(e_field_1, e_field_2), axis=1)
        # Flip the direction of the electric field if the angle between the two is greater or equal to 90 degrees
        e_field_2 = np.where(np.broadcast_to(angles &gt;= np.pi/2., (3, e_field_2.shape[0])).T, -e_field_2, e_field_2)
        # Recalculate the angles
        max_condition = np.linalg.norm(e_field_2, axis=1) &lt; np.linalg.norm(e_field_1, axis=1)*angs
        # Condition to have two times the E1 field amplitude
        max_condition_2 = np.linalg.norm(e_field_1, axis=1) &lt; np.linalg.norm(e_field_2, axis=1)*angs
        e2_gr_e1 = np.where(np.linalg.norm(e_field_2, axis=1) &gt; np.linalg.norm(e_field_1, axis=1), max_condition_2, False)
        # Double magnitudes
        envelope = np.where(e1_gr_e2, 2.0*np.linalg.norm(e_field_2, axis=1), envelope) # 2E2 (First case)
        envelope = np.where(e2_gr_e1, 2.0*np.linalg.norm(e_field_1, axis=1), envelope) # 2E1 (Second case)
        # Cross product
        # Redifine e1_gr_e2 to match the area ouside where the max_condition is met
        e1_gr_e2 = np.where(np.linalg.norm(e_field_1, axis=1) &gt; np.linalg.norm(e_field_2, axis=1), np.logical_not(max_condition), False)
        envelope = np.where(e1_gr_e2, 2.0*(np.linalg.norm(np.cross(e_field_2, E_minus), axis=1)/np.linalg.norm(E_minus, axis=1)), envelope) # (First case)
        e2_gr_e1 = np.where(np.linalg.norm(e_field_2, axis=1) &gt; np.linalg.norm(e_field_1, axis=1), np.logical_not(max_condition_2), False)
        envelope = np.where(e2_gr_e1, 2.0*(np.linalg.norm(np.cross(-e_field_1, -E_minus), axis=1)/np.linalg.norm(-E_minus, axis=1)), envelope) # (Second case)
    else:
        envelope = np.abs(np.abs(np.dot(E_plus, dir_vector)) - np.abs(np.dot(E_minus, dir_vector)))
    return envelope
</code></pre>
]]></description><link>https://forum.zmt.swiss/post/678</link><guid isPermaLink="true">https://forum.zmt.swiss/post/678</guid><dc:creator><![CDATA[dstoupis]]></dc:creator><pubDate>Mon, 18 May 2020 18:18:51 GMT</pubDate></item></channel></rss>
