<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation]]></title><description><![CDATA[<p dir="auto">Assume we have an LF simulation with two electrodes, at + and - 1V, respectively, as shown in the voxel view below. We want to compute the total current flowing between the two electrodes.</p>
<p dir="auto"><img src="/assets/uploads/files/1506927343398-9ab23e8c-d86a-4022-a10f-cb9c60f86150-image-resized.png" alt="0_1506927345681_9ab23e8c-d86a-4022-a10f-cb9c60f86150-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">We start by creating a plane that cut through the computational domain, with each electrode in either part of the plane:</p>
<p dir="auto"><img src="/assets/uploads/files/1506927424367-bc53c93c-1e31-461b-8a96-12420a339a88-image-resized.png" alt="0_1506927426717_bc53c93c-1e31-461b-8a96-12420a339a88-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">We then use the <strong>Flux Evaluator</strong> to compute the total current flowing through the plane:</p>
]]></description><link>https://forum.zmt.swiss/topic/24/compute-the-total-current-flowing-between-two-electrodes-in-an-electro-quasistatic-lf-simulation</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 08:59:43 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/24.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Oct 2017 07:03:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Sat, 26 Jul 2025 10:38:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi, sorry to bother you. Do you happen to know how to calculate the current absorbed by the electrodes and the impedance?</p>
]]></description><link>https://forum.zmt.swiss/post/2270</link><guid isPermaLink="true">https://forum.zmt.swiss/post/2270</guid><dc:creator><![CDATA[lorenero_99]]></dc:creator><pubDate>Sat, 26 Jul 2025 10:38:43 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Mon, 13 Jan 2025 03:57:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sylvain">@<bdi>Sylvain</bdi></a> Hi Sylvain! Thanks for sharing the method. I tried it in this very simple structure but get unexpected result for current density. Also available at my post here <a href="https://forum.zmt.swiss/post/2071">https://forum.zmt.swiss/post/2071</a>.</p>
<p dir="auto">I use the following very simple structure to test whether I am using the LF Ohmic Quasi-Static Solver correctly. The voltage comes out as expected but the current (density) is incorrect. I have these three electrodes of the same radius (1mm) stacking together (touching each other) in an electrode-cylinder-electrode configuration. I want to apply to a 2V (+1V top, -1V bottom) to the two silver electrodes and achieve a 1 kA current through. So I chose the cylinder material (copper) and length such that the resistance is 2 mOhm.</p>
<p dir="auto">After running the simulation, where I place a line as voltage sensor (it runs from 2mm offset from the top electrode to 2mm offset from the bottom electrode, in the centre), it gives a value of -1.9786V as expected.<br />
When I combine the J(x,y,z,f0) from the overall field and a plane I created and use flux evaluator to measure total current density as described here, unexpected resutls occur. I tried two different planes and they gave different results::</p>
<ol>
<li>A block with 0mm thickness and 1m x 1m in area in the middle of the cylinder parallel to the electrodes, result: 1 A/m^2, multiply by the area gives 1A</li>
<li>A cylinder with 0mm thickness and 1mm in radius in the middle of the cylinder parallel to the elctrodes, resutls: 49.7369 A/m^2, multiply by the area gives 0.156mA<br />
(P.S. why the current density has a unit of [A/m^2 m^2]?)</li>
</ol>
<p dir="auto">Model, Simulation and Analysis details are summaried in the screenshots attached. <img src="/assets/uploads/files/1736740622839-img_5162.jpg" alt="IMG_5162.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1736740622913-img_5163.jpg" alt="IMG_5163.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1736740622953-img_5164.jpg" alt="IMG_5164.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1736740634276-screenshot-2025-01-12-at-21.26.50-resized.jpg" alt="Screenshot 2025-01-12 at 21.26.50.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1736740634609-screenshot-2025-01-12-at-21.27.16-resized.jpg" alt="Screenshot 2025-01-12 at 21.27.16.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1736740634957-screenshot-2025-01-12-at-21.27.32-resized.jpg" alt="Screenshot 2025-01-12 at 21.27.32.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1736740635384-screenshot-2025-01-12-at-21.31.17-resized.jpg" alt="Screenshot 2025-01-12 at 21.31.17.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1736740635771-screenshot-2025-01-12-at-21.34.49-resized.jpg" alt="Screenshot 2025-01-12 at 21.34.49.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1736740636120-screenshot-2025-01-12-at-21.35.28-resized.jpg" alt="Screenshot 2025-01-12 at 21.35.28.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.zmt.swiss/post/2072</link><guid isPermaLink="true">https://forum.zmt.swiss/post/2072</guid><dc:creator><![CDATA[Cindy645]]></dc:creator><pubDate>Mon, 13 Jan 2025 03:57:34 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Mon, 12 Feb 2024 11:52:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/halder">@<bdi>halder</bdi></a> Thank you for your response. I want the total current of 1 mA flowing between my two electrodes. In this case, I should put the target value as (1 mA/area of the plane I have drawn between two electrodes)?<br />
since my plane area is 182mm*220mm, then I should select the target value to be 0.024975 A/m2. Is this the correct approach?</p>
]]></description><link>https://forum.zmt.swiss/post/1765</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1765</guid><dc:creator><![CDATA[Paria M.]]></dc:creator><pubDate>Mon, 12 Feb 2024 11:52:22 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Fri, 09 Feb 2024 12:39:17 GMT]]></title><description><![CDATA[<p dir="auto">@Paria-M  You can use the field along with the averaged flux density and then use the field normalizer, for the target value you have to input the current in units of A/m^2.</p>
<p dir="auto"><img src="/assets/uploads/files/1707482295370-e123ade7-fb19-40e4-b8c5-4aed11a6d5bf-image.png" alt="image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1707482334450-94cc11a7-efa0-4918-bec2-ce95ee7b4bd4-image.png" alt="image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.zmt.swiss/post/1762</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1762</guid><dc:creator><![CDATA[halder]]></dc:creator><pubDate>Fri, 09 Feb 2024 12:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Mon, 05 Feb 2024 15:35:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sylvain">@<bdi>Sylvain</bdi></a><br />
Hi, I followed the steps you described in this post to obtain the flux between two electodes in my simulation. The resulted Total Flux is (-1.22514 mA/m^2 m^2). I want to nolmalize the E-field in my simulation to have the current of 1 mA/m^2 m^2 between the electrodes. Could you please guide me on how to do that using the "Field Normalizer" at field data tools section?</p>
<p dir="auto">As seen in the attached picture, when I refresh the Field Normalizer, I get error.</p>
<p dir="auto"><img src="/assets/uploads/files/1707147317465-d9dc8eab-7131-4432-85e9-bc057251fc40-image.png" alt="d9dc8eab-7131-4432-85e9-bc057251fc40-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.zmt.swiss/post/1758</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1758</guid><dc:creator><![CDATA[Paria M.]]></dc:creator><pubDate>Mon, 05 Feb 2024 15:35:49 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Mon, 25 Oct 2021 09:35:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sylvain">@<bdi>sylvain</bdi></a> okay, thank you very much .I will try again.</p>
]]></description><link>https://forum.zmt.swiss/post/1163</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1163</guid><dc:creator><![CDATA[hiTina]]></dc:creator><pubDate>Mon, 25 Oct 2021 09:35:53 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Mon, 25 Oct 2021 06:22:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hitina">@<bdi>hiTina</bdi></a> it's not clear from your post whether you selected both the J field and the surface before clicking "Flux Evaluator".<br />
What I mean is that you should see something like this in the <code>Output View</code> and then click "Flux Evaluator"<br />
<img src="/assets/uploads/files/1635142850279-8768d17a-0430-462b-91b6-b0cd1db12608-image.png" alt="8768d17a-0430-462b-91b6-b0cd1db12608-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Once you've done that, the <code>Workbench</code> would show something like this:<br />
<img src="/assets/uploads/files/1635142937756-df5cca15-502b-4875-8c51-c919fb93fff1-image.png" alt="df5cca15-502b-4875-8c51-c919fb93fff1-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.zmt.swiss/post/1159</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1159</guid><dc:creator><![CDATA[Sylvain]]></dc:creator><pubDate>Mon, 25 Oct 2021 06:22:52 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Fri, 22 Oct 2021 14:22:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sylvain">@<bdi>sylvain</bdi></a> Thanks for your reply. I try to create a plane and drag and drop the plane into the Explorer tree of the Analysis tab.I enable the J(x,y,z,f0) and click the Flux Evaluator button. The result shows errors as follow.<img src="/assets/uploads/files/1634912102591-%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20211022221230.png" alt="微信图片_20211022221230.png" class=" img-fluid img-markdown" /><br />
How can I use the created plane to compute the current?<img src="/assets/uploads/files/1634912191535-%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20211022221225.png" alt="微信图片_20211022221225.png" class=" img-fluid img-markdown" /><br />
Should I set the created plane as the target surface of  the flux evaluator ? the error shows invalid  target surface at input. looking forward to your reply.</p>
]]></description><link>https://forum.zmt.swiss/post/1157</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1157</guid><dc:creator><![CDATA[hiTina]]></dc:creator><pubDate>Fri, 22 Oct 2021 14:22:33 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Fri, 22 Oct 2021 12:34:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hitina">@<bdi>hitina</bdi></a> typically, you would create the plane in the Model tab of Sim4Life, then use it in the Analysis tab. Use the "Model-Tree" window to drag and drop the plane (or any other CAD object, for that matter) into the Explorer tree of the Analysis tab.<br />
This creates a grid (Surface mesh) out of the CAD object that can be used for further postprocessing. Note that its mesh resolution can be changed (you would typically do that later, so you can see how it affects the end results when you refresh the pipeline).<br />
By selecting the "Surface mesh" and any other field quantity (e.g. J(x,y,z,f0)), you can then make use of the "Flux Evaluator" algorithm. Use the Ctrl key to select multiple items.</p>
<p dir="auto">I hope this helps.</p>
]]></description><link>https://forum.zmt.swiss/post/1154</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1154</guid><dc:creator><![CDATA[Sylvain]]></dc:creator><pubDate>Fri, 22 Oct 2021 12:34:44 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Fri, 22 Oct 2021 07:36:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sylvain">@<bdi>sylvain</bdi></a> when we create the plane to compute the current ,I want to know how to set up the plane in the stimulation tab? setting in the boundary condition or else? hope your reply.</p>
]]></description><link>https://forum.zmt.swiss/post/1152</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1152</guid><dc:creator><![CDATA[hiTina]]></dc:creator><pubDate>Fri, 22 Oct 2021 07:36:15 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Tue, 05 Oct 2021 06:10:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gbgbha">@<bdi>gbgbha</bdi></a> the evaluator would typically return a complex number, which should be interpreted as a phasor (at the frequency at which the fields were computed). Take the absolute value of that number to get the peak total current, divide by sqrt(2) to get the RMS.</p>
]]></description><link>https://forum.zmt.swiss/post/1097</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1097</guid><dc:creator><![CDATA[Sylvain]]></dc:creator><pubDate>Tue, 05 Oct 2021 06:10:40 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Mon, 04 Oct 2021 18:05:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/sylvain">@<bdi>Sylvain</bdi></a>, thanks for the tips. Is the total evaluated flux returned in RMS or absolute magnitude?</p>
]]></description><link>https://forum.zmt.swiss/post/1095</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1095</guid><dc:creator><![CDATA[gbgbha]]></dc:creator><pubDate>Mon, 04 Oct 2021 18:05:31 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Mon, 19 Apr 2021 08:48:50 GMT]]></title><description><![CDATA[<p dir="auto">Current intensity is defined for a given cross-section. Usually, it is used for wires, where the cross-section is obvious, and it relates to the "amount of current" passing through the wire. A bit like the amount of water passing under a bridge, for a river (referred to as volumetric flow rate, or "discharge").<br />
For an infinitesimal point, it doesn't make much sense to speak of current intensity (or of flow rate, for the river analogy). The relevant quantity, in that case, is the <strong>flux</strong> of current (or water...), expressed in A/m2 (or volume/s/m2).</p>
]]></description><link>https://forum.zmt.swiss/post/947</link><guid isPermaLink="true">https://forum.zmt.swiss/post/947</guid><dc:creator><![CDATA[Sylvain]]></dc:creator><pubDate>Mon, 19 Apr 2021 08:48:50 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Sat, 17 Apr 2021 02:06:16 GMT]]></title><description><![CDATA[<p dir="auto">Can I consider the current in the body during electrode stimulation like this? First, the simulation result can get the current density. Its unit is A/m². Assuming that the current current density is 100A/m², I want to calculate the current at a certain point in the muscle Intensity, I choose 1mm², then the current density at this time becomes 0.1mA/mm², can I consider the current intensity at the current position as 0.1mA?</p>
]]></description><link>https://forum.zmt.swiss/post/939</link><guid isPermaLink="true">https://forum.zmt.swiss/post/939</guid><dc:creator><![CDATA[daolin_qu]]></dc:creator><pubDate>Sat, 17 Apr 2021 02:06:16 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Tue, 25 Jun 2019 21:03:31 GMT]]></title><description><![CDATA[<p dir="auto">The "Total Loss" approach works too.  Be aware that it assumes that <strong>all</strong> the power dissipated by the system occurs via the Joule effect in conductive materials. In other words, it only accounts for <em>Ohmic</em> currents and neglects the contribution of <em>Displacement</em> current (like the current that flows between the two plates separated by air in a capacitor).<br />
This means you can use this approach if you could have used the <em>Ohmic Quasi-Static</em> solver instead of the <em>Quasi-Static</em> one (since the former neglects displacement currents, while the latter does not).<br />
For currents flowing between electrodes placed on a human body, displacement currents are typically negligible.</p>
]]></description><link>https://forum.zmt.swiss/post/451</link><guid isPermaLink="true">https://forum.zmt.swiss/post/451</guid><dc:creator><![CDATA[Sylvain]]></dc:creator><pubDate>Tue, 25 Jun 2019 21:03:31 GMT</pubDate></item><item><title><![CDATA[Reply to Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation on Tue, 25 Jun 2019 20:22:07 GMT]]></title><description><![CDATA[<p dir="auto">Is there a disadvantage to calculating the current by using the power loss in the simulation domain and avoiding extra geometry? (i.e. R = (V^2)/P and then I = V/R using the "Total Loss" in "All Regions" from the SAR statistics evaluator?)</p>
]]></description><link>https://forum.zmt.swiss/post/449</link><guid isPermaLink="true">https://forum.zmt.swiss/post/449</guid><dc:creator><![CDATA[JKM]]></dc:creator><pubDate>Tue, 25 Jun 2019 20:22:07 GMT</pubDate></item></channel></rss>
