<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Axon getting stimulated even with atto Amps of current !!]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am trying to stimulate axon (SENN model) by applying external electric field of 1V.  To limit the current passing through the tissue, I have increased the impedance of the tissue to make the current on the order of pA (down to aA as well).  I wanted to see the threshold limit for eliciting an AP but even when the current passing through the axon is of the order of aA - it is getting stimulated which doesn't seem right to me.</p>
<p dir="auto">I have a couple of questions -<br />
a) Is there a better way to limit the current generated by the electrodes?  If not, does my approach sound good as the voltage/current is calculated before it is being fed to the neuron and so I think it should be OK.<br />
b) Why the Axon is still getting excited even when the current is so low?</p>
<p dir="auto">I can share the code if someone wants to verify it quickly.</p>
<p dir="auto">For reference, here are the screenshots for the simulations -</p>
<p dir="auto">current plot across the axon -<br />
<img src="/assets/uploads/files/1622081487641-377c6fce-f1f3-4ba4-afe5-f51337f11fa2-image.png" alt="377c6fce-f1f3-4ba4-afe5-f51337f11fa2-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">AP plot along with titration sensor -</p>
<p dir="auto"><img src="/assets/uploads/files/1622081272398-0a0948ad-429d-4953-9b38-3c2cb1405791-image.png" alt="0a0948ad-429d-4953-9b38-3c2cb1405791-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thank you so much for your help.</p>
<p dir="auto">Regards,<br />
Shubham</p>
]]></description><link>https://forum.zmt.swiss/topic/335/axon-getting-stimulated-even-with-atto-amps-of-current</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 04:41:05 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/335.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 May 2021 02:36:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Axon getting stimulated even with atto Amps of current !! on Mon, 31 May 2021 14:52:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/habib">@<bdi>habib</bdi></a></p>
<p dir="auto">Thank you for your reply.</p>
<p dir="auto">I can understand that if you enable the titration, the software keeps on scaling the field till sees a stimulation.  But it also gives us a number for the scaling field.  In this case, I am seeing that number to be 0.13.</p>
<p dir="auto">Doesn't it mean that the field has been scaled down to a factor of 0.13 to create the minimum field for stimulation - I was hoping that number to be orders of magnitude higher.</p>
<p dir="auto">Please correct me if I am wrong.</p>
<p dir="auto">Thanks for looking into this.</p>
]]></description><link>https://forum.zmt.swiss/post/980</link><guid isPermaLink="true">https://forum.zmt.swiss/post/980</guid><dc:creator><![CDATA[shyadav]]></dc:creator><pubDate>Mon, 31 May 2021 14:52:54 GMT</pubDate></item><item><title><![CDATA[Reply to Axon getting stimulated even with atto Amps of current !! on Mon, 31 May 2021 09:56:53 GMT]]></title><description><![CDATA[<p dir="auto">To answer question b)<br />
In this simulation, you have Titration enabled. This is likely to lead to a neural response because it tries to scale the EM potential field until an action potential is detected.<br />
If you disable Titration in the simulation Setup, you will get the neural response under the effect of the potential field scaled by the modulating pulse.</p>
]]></description><link>https://forum.zmt.swiss/post/979</link><guid isPermaLink="true">https://forum.zmt.swiss/post/979</guid><dc:creator><![CDATA[Habib]]></dc:creator><pubDate>Mon, 31 May 2021 09:56:53 GMT</pubDate></item><item><title><![CDATA[Reply to Axon getting stimulated even with atto Amps of current !! on Sun, 30 May 2021 23:09:27 GMT]]></title><description><![CDATA[<p dir="auto">@shyadav. Answering to this question require some investigation of your Sim4Life project. Could you please share with me the simulation file? Please send it to s4l-support@zmt.swiss and to me in cc (cassara@itis.swiss)?</p>
<p dir="auto">Thanks a lot,<br />
Antonino</p>
]]></description><link>https://forum.zmt.swiss/post/977</link><guid isPermaLink="true">https://forum.zmt.swiss/post/977</guid><dc:creator><![CDATA[AntoninoMC]]></dc:creator><pubDate>Sun, 30 May 2021 23:09:27 GMT</pubDate></item></channel></rss>
