<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help with my simulation]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I am trying to create a simulation.</p>
<p dir="auto">I have generated the surface of my model and also I have created a Birdcage (8 legs with radius=180 and length=220)</p>
<p dir="auto">In the simulation tab, I have created a EM EM-FDTD Multiport and I moved my model and the birdcage to this EM-FDTD Multiport. I haven´t changed anything, only in the grid I set auto grid update, and then I created voxels and run.</p>
<p dir="auto">When I do that, Endring 1 and Endring 2 are created successfully but I have a problem that Endring 1 failed but Endring 2 continues simulating.</p>
<p dir="auto">My target is to calculate the SAR for my model. What can I do?</p>
]]></description><link>https://forum.zmt.swiss/topic/348/help-with-my-simulation</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 05:57:46 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/348.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Jul 2021 10:38:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help with my simulation on Fri, 09 Jul 2021 10:11:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi Javier,</p>
<p dir="auto">What error messages are you getting with Endring 1 simulation? I assume that you have already checked the tutorial "3.1.9 MRI Lowpass Volume Coil" which might help you to make sure that your setup is correct.</p>
]]></description><link>https://forum.zmt.swiss/post/1018</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1018</guid><dc:creator><![CDATA[ofli]]></dc:creator><pubDate>Fri, 09 Jul 2021 10:11:34 GMT</pubDate></item></channel></rss>
