<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to export E-field to a custom grid?]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I would like to export the E-field (overall field) to a custom grid. For example, I would like to compare the E-field in a plane perpendicular to antennas placed around the a femur before and after posing. Currently since the E-field can only be extracted according to the global coordinates, I am not able to extract the values I would like.</p>
<p dir="auto"><img src="/assets/uploads/files/1709764164259-dba1b4f1-de5d-4af1-b7e7-32d857344dc7-image.png" alt="dba1b4f1-de5d-4af1-b7e7-32d857344dc7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I would like to extract E-fields perpendicular to the antennas even when posed (the grid remains constant between static and posed models since it is relative to the antennas).</p>
<p dir="auto">How do I proceed with this?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.zmt.swiss/topic/593/how-to-export-e-field-to-a-custom-grid</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Nov 2026 11:26:53 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/593.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Mar 2024 22:30:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to export E-field to a custom grid? on Mon, 11 Mar 2024 23:46:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Thank you. I tried it but would like to plot the fields on a grid between antennas (as shown in red in the image). It is easy when the model is static but when posed, I am not able to get a grid at an angle.</p>
<p dir="auto"><img src="/assets/uploads/files/1710200782830-dd141418-49f3-4854-a083-853ccfa690dd-image.png" alt="image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.zmt.swiss/post/1798</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1798</guid><dc:creator><![CDATA[VigneshYork]]></dc:creator><pubDate>Mon, 11 Mar 2024 23:46:41 GMT</pubDate></item><item><title><![CDATA[Reply to How to export E-field to a custom grid? on Mon, 11 Mar 2024 07:48:42 GMT]]></title><description><![CDATA[<p dir="auto">The easiest way is probably to</p>
<ul>
<li>drag the antenna surface (where you want to obtain the perpendicular field) into the analysis explorer</li>
<li>interpolate the field onto the surface (select the field and the surface, then choose the Interpolator tool)</li>
<li>select normal projection (there is also tangential projection)</li>
<li>visualize with a surface viewer</li>
</ul>
<p dir="auto">if the surface is too coarse, edit the faceting settings of the antenna, or remesh.</p>
]]></description><link>https://forum.zmt.swiss/post/1797</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1797</guid><dc:creator><![CDATA[bryn]]></dc:creator><pubDate>Mon, 11 Mar 2024 07:48:42 GMT</pubDate></item></channel></rss>
