<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[impossible drag and drop from non-CAD models]]></title><description><![CDATA[<p dir="auto">Hi i just working with the monopole simulation tutorial and at the step which say's "Select “Tissue” in the Multi-Tree | Model window and drag and drop it into the simulation parent folder with the name “EM Electrode Stimulation” in the Explorer window. “Tissue” is now associated with this simulation." in the branch 3.6.1.3, i found that it's impossible to drop the tissue to the simulation window. actually when i try to drag and drop any imported cad files to the simulation branch it's working but for the built models , like as this example and tutorial, this won't work. anybody has an idea aboutn that? p.s. i've made sure that i have done the whole simulations process true and exactly same as the tutorial!<br />
<img src="/assets/uploads/files/1718096852784-1.png" alt="1.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.zmt.swiss/topic/615/impossible-drag-and-drop-from-non-cad-models</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 08:16:23 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/615.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Jun 2024 09:07:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to impossible drag and drop from non-CAD models on Sat, 10 May 2025 04:49:54 GMT]]></title><description><![CDATA[<p dir="auto">For the unstructured version of the EM LF Electro you would first need to generate a tetrahedral mesh. The mesh can be dragged onto such a simulation.</p>
]]></description><link>https://forum.zmt.swiss/post/2134</link><guid isPermaLink="true">https://forum.zmt.swiss/post/2134</guid><dc:creator><![CDATA[bryn]]></dc:creator><pubDate>Sat, 10 May 2025 04:49:54 GMT</pubDate></item><item><title><![CDATA[Reply to impossible drag and drop from non-CAD models on Mon, 24 Jun 2024 13:38:44 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your reply. actually i have solved the problem. the problem was that inspite of what the documentation said, I have been selected the wrong study (ohmic quasi stat) under the unstructured EM LF Electro, while i needed to select the EM LF Electro, which could be exert on the structured problems.</p>
]]></description><link>https://forum.zmt.swiss/post/1875</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1875</guid><dc:creator><![CDATA[Shadi_tshkri]]></dc:creator><pubDate>Mon, 24 Jun 2024 13:38:44 GMT</pubDate></item><item><title><![CDATA[Reply to impossible drag and drop from non-CAD models on Mon, 24 Jun 2024 12:17:38 GMT]]></title><description><![CDATA[<p dir="auto">It looks like you could be dragging it onto Setup. For this to work, you need to drag the object directly onto the simulation name, or the material or grid subsections.</p>
]]></description><link>https://forum.zmt.swiss/post/1873</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1873</guid><dc:creator><![CDATA[brown]]></dc:creator><pubDate>Mon, 24 Jun 2024 12:17:38 GMT</pubDate></item></channel></rss>
