<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Errors QS MPI]]></title><description><![CDATA[<p dir="auto">Hi! When running a simulation on an IXI397 phantom with a magnetic field in LF Magneto Quasi-Static, the following solver errors occur (screenshots in attached files). Could you tell me the reason?</p>
]]></description><link>https://forum.zmt.swiss/topic/640/errors-qs-mpi</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 11:24:57 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/640.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Oct 2024 07:15:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Errors QS MPI on Mon, 21 Oct 2024 07:33:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi Andrei, this error shows when there are not enough MPI-QS tokens on your license to use all cores on your computer. If parallelization is set to automatic, Sim4Life iSolve will try to use all available cores, and one MPI-QS token per core is needed. You can change the number of processes (=cores) to be used by setting parallelization to Manual and entering the number of MPI-QS tokens + 1 (solver license).</p>
]]></description><link>https://forum.zmt.swiss/post/1941</link><guid isPermaLink="true">https://forum.zmt.swiss/post/1941</guid><dc:creator><![CDATA[minana]]></dc:creator><pubDate>Mon, 21 Oct 2024 07:33:36 GMT</pubDate></item></channel></rss>
