<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Start the Linux licensing daemon failed]]></title><description><![CDATA[<p dir="auto">trying to start linux licensing daemon but failed, some abnormal info in the debug.log</p>
<ul>
<li>
<p dir="auto">Line 81 - Wrong hostid on SERVER line for license file</p>
</li>
<li>
<p dir="auto">Line 83 - SERVER line says FLEXID=X-XXXXXXXX, hostid is (Can't get hostid of type 15 [Invalid host. (-9,57)])</p>
</li>
<li>
<p dir="auto">Line 84 - Invalid hostid on SERVER line<br />
......</p>
</li>
<li>
<p dir="auto">Line 189 - No valid hostids, exiting</p>
</li>
<li>
<p dir="auto">Line 190 - EXITING DUE TO SIGNAL 34 Exit reason 2</p>
</li>
<li>
<p dir="auto">Line 191 - SPEAG exited with status 34 (Invalid host)</p>
</li>
</ul>
<p dir="auto">Environment</p>
<ul>
<li>
<p dir="auto">Sim4Life V7.2</p>
</li>
<li>
<p dir="auto">Ubuntu 20.04.5 LTS</p>
</li>
</ul>
<p dir="auto">Look forward to your help, thanks.</p>
]]></description><link>https://forum.zmt.swiss/topic/677/start-the-linux-licensing-daemon-failed</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 12:23:41 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/677.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jan 2025 07:34:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Start the Linux licensing daemon failed on Fri, 21 Feb 2025 08:30:35 GMT]]></title><description><![CDATA[<p dir="auto">This looks like the drivers for the dongle are missing or have not been installed. Did you check the manual on how to install drivers for Linux?</p>
<p dir="auto">Also, it would help if you send us the full log. You can do that by emailing us at:<br />
s4l-support-group@zmt.swiss</p>
<p dir="auto">Regards,<br />
Guillermo</p>
]]></description><link>https://forum.zmt.swiss/post/2110</link><guid isPermaLink="true">https://forum.zmt.swiss/post/2110</guid><dc:creator><![CDATA[guillermo]]></dc:creator><pubDate>Fri, 21 Feb 2025 08:30:35 GMT</pubDate></item><item><title><![CDATA[Reply to Start the Linux licensing daemon failed on Fri, 24 Jan 2025 01:26:39 GMT]]></title><description><![CDATA[<p dir="auto">Is there any dongle driver for ARM (aarch64) ?</p>
]]></description><link>https://forum.zmt.swiss/post/2089</link><guid isPermaLink="true">https://forum.zmt.swiss/post/2089</guid><dc:creator><![CDATA[edward]]></dc:creator><pubDate>Fri, 24 Jan 2025 01:26:39 GMT</pubDate></item><item><title><![CDATA[Reply to Start the Linux licensing daemon failed on Tue, 21 Jan 2025 07:38:11 GMT]]></title><description><![CDATA[<p dir="auto">now lmhostid can gotta the right host ID, but lmgrd still the same problem</p>
<p dir="auto"><em>The FlexNet host ID of this machine is "xxxxxxxxxxxx"</em></p>
]]></description><link>https://forum.zmt.swiss/post/2086</link><guid isPermaLink="true">https://forum.zmt.swiss/post/2086</guid><dc:creator><![CDATA[edward]]></dc:creator><pubDate>Tue, 21 Jan 2025 07:38:11 GMT</pubDate></item><item><title><![CDATA[Reply to Start the Linux licensing daemon failed on Tue, 21 Jan 2025 03:20:33 GMT]]></title><description><![CDATA[<p dir="auto">I'using a physical server, run lmhostid will display all 8 nic mac address</p>
<p dir="auto"><em>The FlexNet host ID of this machine is ""xxxxxxxxxxxx xxxxxxxxxxxx xxxxxxxxxxxx xxxxxxxxxxxx xxxxxxxxxxxx xxxxxxxxxxxx xxxxxxxxxxxx xxxxxxxxxxxx""<br />
Only use ONE from the list of hostids.</em></p>
]]></description><link>https://forum.zmt.swiss/post/2085</link><guid isPermaLink="true">https://forum.zmt.swiss/post/2085</guid><dc:creator><![CDATA[edward]]></dc:creator><pubDate>Tue, 21 Jan 2025 03:20:33 GMT</pubDate></item><item><title><![CDATA[Reply to Start the Linux licensing daemon failed on Mon, 20 Jan 2025 09:03:16 GMT]]></title><description><![CDATA[<p dir="auto">Before that, it shows “Can't make directory /usr/tmp/.flexlm, errno: 2(No such file or directory)”</p>
]]></description><link>https://forum.zmt.swiss/post/2084</link><guid isPermaLink="true">https://forum.zmt.swiss/post/2084</guid><dc:creator><![CDATA[franklin]]></dc:creator><pubDate>Mon, 20 Jan 2025 09:03:16 GMT</pubDate></item></channel></rss>
