<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[S4L Scripting VS Code Extension Cannot Run or Debug Python Script via Remote-SSH Despite Successful Connection]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am experiencing an issue with the S4L Scripting extension in VS Code.</p>
<p dir="auto">Sim4Life is running on a server within a local area network. On my local machine, I use VS Code with Remote-SSH to connect to the server. The S4L Scripting extension is installed on the server side, and the compiler path has been correctly configured. The extension settings are shown below:</p>
<p dir="auto"><img src="/assets/uploads/files/1779433175987-4006d4e9-9451-42c9-a73f-37966d3b46ea-image.png" alt="4006d4e9-9451-42c9-a73f-37966d3b46ea-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">When I run the command <code>S4L: Identify</code> in VS Code, the extension notification shows that the connection is successful. The Sim4Life terminal on the host machine also indicates that it has successfully connected to the extension.<br />
<img src="/assets/uploads/files/1779433210405-e3c60d40-1b59-47ca-9824-45fc90fd0075-f4269e7a12cadecc781cf16a3be80c53.png" alt="e3c60d40-1b59-47ca-9824-45fc90fd0075-f4269e7a12cadecc781cf16a3be80c53.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1779433221360-0d2a92f7-c570-4bd8-bf97-6eee6f752132-131ab56bcce2ff3d6f31078f3aa4fe12.png" alt="0d2a92f7-c570-4bd8-bf97-6eee6f752132-131ab56bcce2ff3d6f31078f3aa4fe12.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">When I run <code>S4L: Open Current Script</code>, the target script can also be opened correctly in Sim4Life.</p>
<p dir="auto">However, when I try to execute the script using <code>S4L: Run Python Script</code>, the extension notification says that there is currently no running Sim4Life process. The same issue occurs when I try to run the debug command for the script.</p>
<p dir="auto"><img src="/assets/uploads/files/1779433278245-0a38697d-5876-4785-b791-77a6e0389530-d86d1462f21252c4624f7077af6c2a84.png" alt="0a38697d-5876-4785-b791-77a6e0389530-d86d1462f21252c4624f7077af6c2a84.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I have tried changing several extension settings as well as the Python-related settings inside Sim4Life, but I still cannot run scripts through the extension.</p>
<p dir="auto">My Sim4Life Python configuration is shown below:</p>
<p dir="auto"><img src="/assets/uploads/files/1779433298458-dc2befc6-ceff-433a-b983-6933efeafece-ed6f244a62718e45c2dfa0f9b91a5291.png" alt="dc2befc6-ceff-433a-b983-6933efeafece-ed6f244a62718e45c2dfa0f9b91a5291.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I have confirmed that the <code>Extension Communication Port</code> setting is the same in both Sim4Life and the VS Code extension. I have also confirmed that the system firewall allows traffic through this port.</p>
<p dir="auto">Could you please help me what might be causing this issue?</p>
<p dir="auto">Thank you for your help.</p>
]]></description><link>https://forum.zmt.swiss/topic/785/s4l-scripting-vs-code-extension-cannot-run-or-debug-python-script-via-remote-ssh-despite-successful-connection</link><generator>RSS for Node</generator><lastBuildDate>Fri, 22 May 2026 12:34:39 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/785.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 May 2026 07:03:10 GMT</pubDate><ttl>60</ttl></channel></rss>
