<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Electrode appears hollow after voxelisation]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am setting up an LF Electro Ohmic Quasi-Static simulation using the DUKE_POSABLE 3.2 model. I have placed two solid spherical electrodes in contact with the body and applied Dirichlet boundary conditions.</p>
<p dir="auto">After voxelisation, the electrodes appear hollow or lattice-like, as shown in the attached screenshots, even though the original geometries are solid. I used a local 1 mm grid for the electrodes, while the anatomical model has a maximum grid step of 2 mm.</p>
<p dir="auto">Could you please explain what may be causing this appearance? Is it only a visualisation effect, or does it mean that the electrode interiors have not been filled with voxels?</p>
<p dir="auto">If the electrodes are actually voxelised as hollow structures, could this affect the electrical contact with the tissue, including the calculated current distribution or contact impedance? Also, is there a way to check whether the electrode material has been correctly assigned throughout the entire electrode volume?</p>
<p dir="auto">Thank you.</p>
<p dir="auto">Here is the screenshort of the voxel:<br />
<img src="/assets/uploads/files/1789648394768-screenshot-2026-09-17-104009.png" alt="Screenshot 2026-09-17 104009.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Screenshort on simulation settings:<br />
<img src="/assets/uploads/files/1789648532529-screenshot-2026-09-17-104234.png" alt="Screenshot 2026-09-17 104234.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.zmt.swiss/topic/788/electrode-appears-hollow-after-voxelisation</link><generator>RSS for Node</generator><lastBuildDate>Thu, 17 Sep 2026 16:39:24 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/788.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Sep 2026 12:34:18 GMT</pubDate><ttl>60</ttl></channel></rss>
