<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SAR evaluation reports "grid too coarse", but works after cropping]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am having an issue when evaluating SAR results in Sim4Life.</p>
<p dir="auto">When I try to view the SAR result (e.g., psSAR IEEE/IEC 62704-1 Avg.SAR(x,y,z,f0)) over the original simulation domain, Sim4Life reports an error indicating that the grid is too coarse, and I cannot obtain the SAR result.</p>
<p dir="auto">However, if I first use Crop to reduce the analysis region to a smaller area around the region of interest, the SAR evaluation works and I can successfully visualize the SAR distribution.</p>
<p dir="auto">The underlying simulation results and grid remain unchanged; I am only changing the spatial region used for post-processing.</p>
<p dir="auto">Could you please clarify why cropping the analysis region changes whether the SAR evaluator considers the grid sufficiently fine?</p>
<p dir="auto">In particular:</p>
<p dir="auto">Could a coarse-grid region somewhere outside my region of interest cause the SAR evaluation for the whole domain to fail?<br />
If the SAR result becomes available after cropping out those regions, can the SAR values within the cropped region be considered valid, or should I refine the simulation grid and rerun the simulation?</p>
<p dir="auto">Thank you for your help.</p>
]]></description><link>https://forum.zmt.swiss/topic/792/sar-evaluation-reports-grid-too-coarse-but-works-after-cropping</link><generator>RSS for Node</generator><lastBuildDate>Mon, 21 Sep 2026 18:28:53 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/792.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Aug 2026 22:15:07 GMT</pubDate><ttl>60</ttl></channel></rss>
