<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calculation of the tangential E-field integral along a base line using IMSAFE.]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">To calculate the tangential E-field integral along a wire using IMSAFE, I extracted the tangential E-field along 10 random splines using 10 disks (the radius of the disks are the same as the radius of the wire) in a text file. To calculate the integration of the tangential E-field along the base-line, I calculate tangential-component magnitude as "E_T = Sqrt((real-tangent-comp)^2+(imag-tangent-comp)^2)" and then I calculate "Sum(dist-along-line. E_T)" for each line. Then I average over the values for 10 random lines to get the value of the integration of tangential E-field along the base line.  Is that a correct procedure?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.zmt.swiss/topic/90/calculation-of-the-tangential-e-field-integral-along-a-base-line-using-imsafe</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 15:33:41 GMT</lastBuildDate><atom:link href="https://forum.zmt.swiss/topic/90.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Nov 2018 17:00:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calculation of the tangential E-field integral along a base line using IMSAFE. on Fri, 16 Nov 2018 17:05:47 GMT]]></title><description><![CDATA[<p dir="auto">Can't you do the same procedure directly for the E_tan along the baseline, instead of doing it for the random splines?</p>
]]></description><link>https://forum.zmt.swiss/post/202</link><guid isPermaLink="true">https://forum.zmt.swiss/post/202</guid><dc:creator><![CDATA[Sylvain]]></dc:creator><pubDate>Fri, 16 Nov 2018 17:05:47 GMT</pubDate></item></channel></rss>
