  4. Creating a wire from a line/arc
Scheduled Pinned Locked Moved Solved Python API
6 Posts 2 Posters 1.7k Views 2 Watching
  • PeterStijnmanP Offline
    PeterStijnman
    wrote on last edited by PeterStijnman
    So in Sim4Life I can create a line and through the GUI it is possible to give this line a certain thickness (using the modify tab and clicking thicken wire). However I cannot seem to find this option in the Sim4Life API, does anyone know if this is possible? I'm using V3.4.1.2244
    So a snippet of the code I use is given below
    from s4l_v1.model import Vec3
    import math
    Wire1 = model.CreateArc(Vec3(0,0,0), 10, float(10)/180*math.pi,float(350)/180*math.pi)
    Wire1.Name = 'MetalWire'
    # Thicken Wire...
      PeterStijnman
      So I sort of found the solution...
      import math
      import XCoreModeling
      def get_spline_length(spline):
      	wire = XCoreModeling.GetWires(spline)[0]
      	return wire.GetLength()
      def Thicken_Wire(spline,radius):
      	target_curve = wire.GetGeometry(transform_to_model_space=True)
      	# compute the length of the spline
      	height = get_spline_length(spline)
      	# get the Vec3 of the starting and end points
      	startVec = target_curve.Eval(0.0)
      	endVec = target_curve.Eval(height)
      	# create a cylinder that will be bend to the spline, its height must be the same as the length of the spline
      	Wire1 = XCoreModeling.CreateSolidCylinder(startVec,Vec3(startVec[0]-height,startVec[1],startVec[2]),radius)
      	# do the bending
      	XCoreModeling.BendBodyToCurve(Wire1,startVec,Vec3(startVec[0]-height,startVec[1],startVec[2]),Vec3(0,0,1),target_curve)
      	# remove the used spline
      	spline.Delete()
      	return Wire1
      # example
      spline1 = model.CreateArc(Vec3(0,0,0), radius, float(10)/180*math.pi,float(350)/180*math.pi)
      Wire1 = Thicken_Wire(spline1,1)
        As you noticed, the Thicken Wire tool is not available in the Python API at the moment (Sim4Life 4.0.1).
        Thank you for sharing your clever solution!
          PeterStijnman
          Thanks, I was wondering if there is a way for me to flag this as 'solved'?
            First, the post as to be "Asked as Question" (unfortunately, I haven't found a way to make that the default behavior). Only then can the post be marked as "Solved". These options are available in "Topic Tools".
              PeterStijnman
              Okay good to know!
