  4. Importing and exporting coordinates for an array of points
15 Posts 3 Posters 9.8k Views 3 Watching
  • F Offline
    F Offline
    fanruifu
    Not sure if that will solve your problems. To export results, go to the 'analysis' page, in the 'output view' section, right-click on the one you want to export, choose 'Imp/Export----Text Exporter'. Then in the properties section, click the 'Refresh' button and you can find the file in the FIle path folder.
    To get coordinates, go to the 'model' page, choose the model, then click 'tool---Geometry'.
      hi @mkn
      here is some example code that exports the currently selected points as a csv file:
      def dump_selected_points(fname):
          sel = XCoreModeling.GetActiveModel().SelectedEntities
          sel = XCoreModeling.CollectEntities(sel)
          with open(fname, "w") as file:
              for e in sel:
                  if isinstance(e, XCoreModeling.Vertex):
                      x = e.Position
                      file.write("%g, %g, %g\n" % (x[0], x[1], x[2]))
      M 1 Reply Last reply
        mkn
        wrote on last edited by mkn
        Thank you, @fanruifu!
          mkn
          Thank you very much for your reply @bryn! I appreciate the help.
            hi @mkn
                    for e in sel:
                            x = e.Position
            mkn
            @bryn I am wondering if it is possible to specify groups of points rather than having to select the points manually. I have a large number of groups with points that I want to export to separate files, and selecting each and executing the code can be quite time consuming.
            Thanks again!
              the code will dump all points in a single file. this will work also if you select multiple groups.
              • sel = XCoreModeling.CollectEntities(sel) will recursively add all children of selected entities
              • if isinstance(e, XCoreModeling.Vertex): will filter out any non-Vertex entities, like groups, meshes, etc.
                mkn
                Thanks @bryn! That will dump them all points in a single file and I want the points in each group to be saved in a separate file. What I would like to do is carry out the same operation but for a certain group name rather than through selection.
                  @mkn
                  this could be done in different ways, but how about the following:
                  import os
                  def dump_selected_points(dir):
                      for e in XCoreModeling.GetActiveModel().SelectedEntities:
                          dump_recursively(e, dir)
                  def dump_recursively(entity, dir):
                      sel = XCoreModeling.CollectEntities([entity])
                      with open(os.path.join(dir, entity.Name + ".txt"), "w") as file:
                          for e in sel:
                                  x = e.Position
                    mkn
                    Thanks @bryn! Just to confirm directory here would be a list of text file names, correct?
                    Also, would it be possible to add the points from each group to a list while saving them to file? Sometimes I would need to do this to create splines or polylines using those point groups.
                    Thanks again!
                      1. os.path.join(dir, entity.Name + ".txt") is a file path inside the directory dir. since the file name is taken from the entity name (depending on selection a group or some other entity), you should take care to assign unique names to the entities.
                      2. yes, just collect the points x and return them.
                        mkn
                        Thanks! This what I did when adding elements to a single list:
                        pts = []
                        for e in sel:
                        if isinstance(e, xcm.Vertex):
                        x = e.Position
                        pts.append(x)
                        I'm not sure how to append to different lists.
                        I appreciate the help!
                          if you return the pts from dump_recursively, you can collect a list of list of points like so:
                          list_of_pts = []
                              pts = dump_recursively(e) # returns the points list from inside a group
                              list_of_pts.append(pts)
                            mkn
                            The code runs and 'txt' files are saved with the point coordinate, but 'list_of_pts' comes back empty for some odd reason.
                              @mkn how about you post your code. maybe somebody will show you where the bug is
