  4. How to Change Material Properties with Python?
Scheduled Pinned Locked Moved Solved Python API
emfdtdpythonmaterialpython api
5 Posts 4 Posters 1.9k Views 5 Watching
  • D Offline
    D Offline
    dbsim4
    wrote on last edited by dbsim4
    I'm trying to change EMFDTD material properties in a simulation that's already set up, using the VIP Body Models.
    If I change the conductivity value, it immediately resets itself to the original value - how do I get it to keep my new value?
    I'm getting "s" from this answer, to get the list of materials:
    https://forum.zmt.swiss/topic/16/how-to-update-material-settings-using-the-material-database-from-python/2
    Thank you!
    • D dbsim4 marked this topic as a question on
    • K Offline
      K Offline
      Konohana
      Hey there,
      I am not sure if this will fix your issue, but I can provide you with a piece of code that I used to apply material settings to the tissues in my simulations:
      # dictionary containing all tissue names and entities in the simulation:
      all_tissues_present = {}
      if 'Bone_cortical' in all_entities:
      	print('Bone assigned')
      	entity_bone1 = all_entities["Bone_cortical"]
      	all_tissues_present["Bone_cortical"] = entity_bone1
      # Dictionary containing material properties such as conductivity
      tissue_conductivities = {
      	'Scalp': [0.439, 1],
      	'Cerebrum_white_matter': [0.348, 10],
      	'Cerebrum_grey_matter': [0.419, 9],
      	'Cerebrospinal_fluid': [1.88, 8],
      	'Bone_cortical': [0.00645, 3],
      # Code to assign material settings to the correct tissues. Using the dictionaries above this can then be done in a for-loop:
      for tissue_name, tissue_entity in all_tissues_present.items():
           material_settings = emlf.MaterialSettings()
           components = [tissue_entity]
           material_settings.Name = tissue_name
           material_settings.ElectricProps.Conductivity =
           tissue_conductivities[tissue_name][0], Unit("S/m")
           simulation.Add(material_settings, components)
      I hope this helps and wish you a very nice day.
      Best
      • D Offline
        D Offline
        dbsim4
        Thank you very much, this is really helpful!
        How do you access the initial "all_entities" list?
        I've tried
        for e in model.AllEntities:
        	print(e)
        but I this error:
        TypeError: 'type' object is not iterable
          try for e in model.AllEntities():
            michaelsch
            Mesh_material = sim.AddMaterialSettings(themesh(fromstl))
            Mesh_material.Name = yourname
            Mesh_material.ElectricProps.Conductivity = v # S/m
            • SylvainS Sylvain has marked this topic as solved on
