Define what GPU to use in a multi-GPU compute environment
Simulations & Solvers
4
Posts
2
Posters
1.3k
Views
2
Watching
This can be done in Ares, under the section "System Information Settings">"GPU">"Allow to use this GPU". You have to only enable the GPU that you wish to use. -
This can be done in Ares, under the section "System Information Settings">"GPU">"Allow to use this GPU". You have to only enable the GPU that you wish to use.@Mélina This is close to what I want but not exactly. I still want ARES to say I can use both GPU's but I want to be able to say "for simulation 1 run on GPU0, for simulation 2 run on GPU1" . Is there anyway to do this? I tried messing around with the concurrent jobs number (setting it to 2 or 3 or 1) in ARES but I don't believe it's working correctly as I still am only running 1 simulation at a time in the queue.
