  4. Delete Simulation and Results
13 Posts 4 Posters 7.6k Views 4 Watching
    LJ
    Thank you @Sylvain!
    • L LJ
      Thank you @Sylvain!
      @lj said in Delete Simulation and Results:
      Thank you @Sylvain!
      you're welcome!
      I would also recommend using the auto-completion feature in the Console. For example, if you type
      sim=document.AllSimulations[0]
      to assign the sim variable and then sim followed by a . (dot) , you should see all the functions that you can use with this simulation object. Usually easier than trying to remember all of them 🙂
        LJ
        Yeah, I do use it. Its very helpful! I guess the mistake I was making was trying to find the delete/ remove within sim rather than document.allsimulations.
          yes, that one is not very obvious indeed. A hint might be given by looking at how simulations are "added" to the project (see for example the auto-generated code when you select a simulation and click "To-Python").
            LJ
            That makes sense- thank you!
              michaelsch
              sim.ClearResults() # delete results
              sim.ResetVoxels() # delete voxels
              document.AllSimulations.Remove(sim) # remove simulation from project
              after adding this lines i got this error :
              Analysis : [Warn] Results Were Deleted
              Analysis : [Warn] Results are not ready and simulation could not be located
              Analysis : [Error] sim 2: Failed to compute output attributes
              Analysis : [Error] Overall Field: Could not update input attributes
              Analysis : [Error] EM E(x,y,z,f0) - Slice Viewer: Could not update input attributes
              Analysis : [Error] EM Potential(x,y,z,f0) - Slice Viewer: Could not update input attributes
              Analysis : [Error] EM E(x,y,z,f0) - Streamline Viewer: Could not update input attributes
                michaelsch
                also h5 output files disappear !
                  LJ
                  can you provide a bit more detail about what you're trying to do?
                    michaelsch
                    i load several meshes one of them is moving and also each time it transmit other frequency, so for each state i need different simulation (sweep not good for me)
                      LJ
                      wrote on last edited by LJ
                      Hmm I am not sure I understand. Is it possible to share more of your code and explain exactly what is not working?
                      I use the lines of code you posted regularly and it works just fine.
