Masking entities in python
Hello Sim4Life community,
I have problems changing the mask setting using the python API. I want to export data where the background is masked away. If I do it interactively in Sim4Life and choose 'to Python' the masking part of the code (setting entities to True/False) seems to be missing. I think I have to use the 'SetMaterial' function in the Analysis.Core.FieldMaskingFilter. I just can't figure out what input type it wants for the materials.
Any help would be wonderful. This is my code:
import numpy
import s4l_v1.units as units
from s4l_v1 import ReleaseVersion
from s4l_v1 import Unittry:
# Define the version to use for default values
ReleaseVersion.set_active(ReleaseVersion.version6_2)size = numpy.linspace(1,34,34) for k in size: # Creating the analysis pipeline # Adding a new SimulationExtractor simulation = document.AllSimulations["Simulation " + str(k)] simulation_extractor = simulation.Results() # Adding a new EmSensorExtractor em_sensor_extractor = simulation_extractor["Overall Field"] em_sensor_extractor.FrequencySettings.ExtractedFrequency = u"All" em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters document.AllAlgorithms.Add(em_sensor_extractor) # Adding a new FieldMaskingFilter inputs = [em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]] field_masking_filter = analysis.core.FieldMaskingFilter(inputs=inputs) field_masking_filter.UpdateAttributes() document.AllAlgorithms.Add(field_masking_filter) # Adding a new MatlabExporter inputs = [field_masking_filter.Outputs["EM E(x,y,z,f0)"]] matlab_exporter = analysis.exporters.MatlabExporter(inputs=inputs) matlab_exporter.FileName = u"[some path]"+str(k)+".mat" matlab_exporter.UpdateAttributes() matlab_exporter.Update() document.AllAlgorithms.Add(matlab_exporter)except Exception as exc:
import traceback
traceback.print_exc(exc)
# Reset active version to default
ReleaseVersion.reset()
raise(exc)Best,
Frodi -
import numpy
import traceback
raise(exc)Best,
Frodi@frodi
I have a similar problem too.
You may see my workaround in the post entitled as: ‘Exporting Simulation Results for Specific Tissues’.If you have a limited number of tissues, you may use my workaround. However, if the number of tissues are changing, then we need a different solution.
Here is an example how you can change the mask programmatically, for materials that where already voxeled in the simulation:
inputs = [em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]] field_masking_filter = analysis.core.FieldMaskingFilter(inputs=inputs) # - clear mask field_masking_filter.SetAllMaterials(False) # - add ventricles to mask materials = field_masking_filter.VoxeledMaterials()() for m in materials: if "Ventricle_lumen_left" in m.Name or "Ventricle_lumen_right" in m.Name: field_masking_filter.SetMaterial(m.ID, True) field_masking_filter.Update()And here is an example of how you can use entities from the modeler:
inputs = [em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]] field_masking_filter = analysis.core.FieldMaskingFilter(inputs=inputs) # somehow select certain entities entities = s4l.model.EntityList() selection = [e for e in entities if "Cerebellum" in e.Name] masking_filter.SetEntities(selection) # expects List[Entity] masking_filter.Update(0) -
inputs = [em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]] field_masking_filter = analysis.core.FieldMaskingFilter(inputs=inputs) # somehow select certain entities entities = s4l.model.EntityList() selection = [e for e in entities if "Cerebellum" in e.Name] masking_filter.SetEntities(selection) # expects List[Entity] masking_filter.Update(0)thank you for posting the code here, however could you please specify what should be the J_port in
masking_filter.SetInputConnection(0, J_port)line of your code?
Further in console, I got warning that this feature is DEPRECATED and it is recommended to use Inputs[key].Connect() however when I try to use
masking_filter.Inputs[inputs].Connect()I receive error that there is no attribute Connect()
Spuky
@Spuky sorry, I guess the legacy code was confusing:
masking_filter = s4l.analysis.core.FieldMaskingFilter() masking_filter.SetInputConnection(0, J_port)I edited the original answer to use the current API. The J_port was the output port for the
J(x,y,z,f0)field. -
J(x,y,z,f0)field.
