  4. how to set the weights of field combiner in python?
Scheduled Pinned Locked Moved Solved Python API
4 Posts 2 Posters 1.5k Views 2 Watching
    Aiping
    Z43
    I found the function, myfieldcombiner.SetWeights(). But I don't know how to specify the weights of the two inputs. for example: 1+0j and -1+0j.
      Here is an example I used in the past (with Sim4Life v3.0), maybe it works for you?
      sim = document.AllSimulations[0]
      results = sim.Results()
      sim_combiner = results.GetSimulationCombiner()
      sim_combiner.UpdateAttributes()
      weights = sim_combiner.GetChannelWeights()
      for n, channel in enumerate(weights):
      	power, phase = weights[channel]
      	weights[channel] = power, 45*n
      for channel in weights:
      	print channel, weights[channel]
      	sim_combiner.SetChannelWeight(channel, *weights[channel])
        Aiping
        Z43
        Thanks, I will try that.
          sorry, I gave you some code for the Simulation Combiner, not the Field Combiner...
          This is how you can use the GetWeights and SetWeights functions for the field combiner:
          >>> field_combiner.GetWeights()
          ((1+0j), (1+0j))
          >>> field_combiner.SetWeights( ( (2+0j), (-3+0j) ) )
