Line fed slot antenna
CAD Modeling
4
Posts
2
Posters
1.5k
Views
2
Watching
I would like to check how to provide input (edge source) for a slot monopole antenna with a shortened ground plane (images attached).
I have followed the patch antenna tutorial but not sure how to work with this ground planeGround plane
Patch
Thanks,
Vignesh -
You could make the substrate the same size of the ground plane and shorten the patch microstrip line, so that you could still draw an axis-aligned polyline which connects microstrip line and ground plane (as in the microstrip-fed patch antenna tutorial).
Thank you. But that would make the ground plane the same size of the substrate face. The paper suggests having a smaller ground plane to improve the power transmitted
