  4. RuntimeError: Could not allocate memory for numpy array
pythonnumpyallocation
3 Posts 2 Posters 2.8k Views 2 Watching
    A relatively common error happen when trying to access the raw data at postprocessing, for example the script:
    import numpy
    import s4l_v1.units as units
    # Creating the analysis pipeline
    # Adding a new SimulationExtractor
    simulation = document.AllSimulations[0]
    # Adding a new EmSensorExtractor
    em_sensor_extractor.FrequencySettings.ExtractedFrequency = u"All"
    em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters
    document.AllAlgorithms.Add(em_sensor_extractor)
    # Adding a new SliceFieldViewer
    E_field = em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]
    raw_data = E_field.Data.Field(0)
    produces the following error:
    Traceback (most recent call last):
    File "C:\Users\user\Documents\Sim4Life\4.2\Scripts\temp\temp-10.py", line 22, in <module>
    RuntimeError: Could not allocate memory for numpy array.
    The reason for the error is that at the last line of the script, Sim4Life has not yet evaluated the analysis pipeline, so the data is not loaded and no memory has been allocated for it.
    The fix is quite simple: simply force the analysis pipeline to update before trying to access the data, using
    E_field.Update()
    The full script now looks like this:
    simulation = document.AllSimulations["Dipole (Broadband)"]
    E_field.Update()
      guoran188
      Thanks. But how to release the memory after using? like, clear the E_field and release the memory it occupies. I tried to open a new project from s4l_v1.document, but it does not work.
        have you tried overwriting the E_field and raw_data variables?
