  4. Algorithm "Max Modulation" was not yet exposed in the Python API
19 Posts 3 Posters 11.0k Views 3 Watching
    Additionally, my boundary is set to 1V, and I want to normalize it to 1mA. In the GUI, I need to model a box to calculate the scale factor, but it is a bit cumbersome to create a box in the script to cover each electrode. Is there a better way to quickly normalize it?
      @lucky_lin
      Regarding normalizing the field between the electrode, you could use the current extractor tool.
      1. After running your simulation in the Analysis Tab, select the simulation and extract the "Overall Field"
      2. Select the overall field, click on the "Field Data Tools" in the ribbon, and select "Current Extractor". This output gives the current in the system in units of Amps.
      3. Select the "Overall Field" and in the Controller select "EM E(x,y,z,f0)". Following this click on "Field Data Tools" in the ribbon again. Select "Field Scaling" now.
      4. Change the scale factor in the controller window based on the following formula (1/Flux*1000) since you want it to be normalized to 1mA. Use the current value you have extracted for the following calculation.
      5. Click Refresh.
      6. Then select the scaled electric field and use the slice viewer to plot it.
      Attached is the code below
      temp-35.py
      C L 2 Replies Last reply
      • L lucky_lin
        Can the maximum value of the TI envelope currently only be calculated through the GUI interface?
        @lucky_lin
        With Sim4Life 8.2, which is the latest version available TI envelope can only be calculated with GUI interface. But this will soon be available with the next release.
        L 3 Replies Last reply
        • H halder
          @lucky_lin
          @halder Thank you very much! Looking forward to the next version! ^^
          • H halder
            @lucky_lin
            @halder I ran your code and encountered the following error: Traceback (most recent call last):
            File "F:\Huilin\sim4life_pro\script\head_segment.py", line 826, in <module>
            comp1 = output1.Data.GetComponent(0)
            RuntimeError: Could not allocate memory for numpy array.
            File "F:\Huilin\sim4life_pro\script\head_segment.py", line 875, in <module>
            raise(exc)
            My memory is 256GB, and I checked the Task Manager and found that not much memory was being used. So I ran it two more times, and the third time it succeeded, but I received a warning:
            Analysis : [Warn] Found 451673 NaN (not a number) values (81.96 %)
            • H halder
              @lucky_lin
              @halder Why is the file not in .smash format after I save it? How should I load the file again after closing the software?
                wrote on last edited by halder
                @lucky_lin yes this RunTimeError is related a Update you have to do, notice line 32 in my code please keep that line.
                  The current extractor essentially calculates the current between two electrodes by integrating the current density field through a closed surface (defined as an isopotential surface surrounding one electrode -the user can use the default isopotential value or customize it, this will affect this number of NaNs). To access these parameters as part of your code use the following:
                  current_extractor.IsoSurfacePerCentThreshold = Enter Value
                  current_extractor.SurfaceRefinement = Enter Value
                  • L lucky_lin
                    @lucky_lin I am a bit confused with what you mean by this, can you upload a screenshot?
                    • H halder
                      @lucky_lin
                      5. Click Refresh.
                      temp-35.py
                      cjanaya
                      @halder thank you for the explanation and laying out the steps for scaling the field. I'm also trying to normalize my current to 1mA in my simulations. However, I'm running an older version of sim4life, v6.2. Is this "Current Extractor" tool only available in newer versions of the software? Are there any concerns with backwards compatibility of previous models if I were to update to the current version of sim4life?
                      I was following the steps on an old post and using the "Total Flux" to evaluate my currents. Would an equivalent method to the "Current Extractor" tool be to evaluate "Total Flux" for the Absolute Value of J field on the surface of my boundary condition? Thanks in advance
                      • H halder
                        • H halder
                          @halder Does using the default equipotential value affect the accuracy of normalization? Can NaN be completely eliminated?
                          • H halder
                            @halder I have the line of code 'update', but it still reports an error.
                            • H halder
                              • L lucky_lin
                                #16
                                @halder This is the max modulation value I extracted, and the vast majority of the values are NaN. However, when I checked the slice viewer, I didn't notice any issues. Are these NaN values treated as 0 in the slice viewer? I extracted this value to create a 3D dataset, so I'm a bit confused about how to handle these NaN values.aaf9e88d-cb7e-4fb4-b7db-530bfcbc1b79-image.png
                                  As mentioned changing IsoSurfacePerCentThreshold/SurfaceRefinement will effect the NaNs calculated. I would start with using the default, then before extracting the field quantities applying a NaN filter (which will replace it with 0s) and then exporting the data. Then go back and recalculate using the current extractor by refining these quantities and follow the same procedure and check what the difference is just to be sure.
                                  • H halder
                                    @lucky_lin
                                    5. Click Refresh.
                                    temp-35.py
                                    @halder After normalizing both Overall Fields to 1mA and using Max Modulation, I see that there are two weights. What is the purpose of this? If I want to see the superimposed field of 1.8mA and 0.2mA, which corresponds to a 9:1 TI field, should I normalize the Overall Fields to 1.8mA and 0.2mA respectively and then calculate using Max Modulation with weight of 1 and 1 , or should I directly use the fields normalized to 1mA and then use weights of 9 and 1 for Max Modulation?8d2774ae-2e0a-4ec8-bb3d-dbc7f7f48365-{3608EF5C-84E6-4DFA-82AF-359527FA319D}.png
                                    • H halder
                                      @halder When I performed TI simulation using the spherical model, I found that if I changed the current direction of one pair of electrodes, the maximum value of the TI Max (x, y, z) slice remained unchanged. Changing the current of one pair of electrodes should have shifted from the original same-direction superposition to a reverse weakening, so why does it remain unchanged? Is it because Max Modulation only uses EM for calculations?
