Normal vector to a tissue surface
to extract the inner normal vector to the cortical surface
- mask the field (set NaN outside GM) using the Mask Filter available under "Field Data Tools" in the top ribbion.
- add the Grey Matter Surface in the post-pro
- interpolate the (masked) field to the grey matter surface using the "Interpolator" which is active when the masked field and surface is selected.
- get the normal component via the NormalFieldEvaluator under the "Field Data Tools"
