Modulated source in thermal simulation
Hi.
I am trying to simulate thermal outcome of electroporation by simulating high electric field on two metal electrodes (I am using LF electro-static simulation to simulate the static field). I need the field to turn on and off acording to time series of short pulses, therefore I want to use modulation of SAR output field and link it to a transient heat source in thermal simulation. Is there any way how to do that in GUI? How can I link simulation source with an analysis output? There is no output name to select.
Hi, sorry for the late reply. This is a great question and I think you have done almost everything right! The only thing that may be incorrect is that you (presumably) applied the Modulation on the SAR(x,y,z) field of the Electro Static simulation, instead of applying it to the field name El. Loss Density(x,y,z,f0)
If you do so, it should appear in the list of output names to select from.
