  4. Importing STL as Solid body
5 Posts 2 Posters 157 Views 2 Watching
  • T Offline
    T Offline
    tiwwexx
    wrote last edited by
    Simple question but hard to find the solution. When importing an STL file via model.Import(filepath), it imports as a triangle mesh. However, when I do this import manually I get an options box that pops up asking if I want to import as a solid body. Is there some option or flag I can use during the import python line that looks something like Import(filename, asSolid=True)? The reason why I want to do this is because the surface current viewer in the analysis tab only works for solid bodies, not these mesh grid objects.
    Thanks for the help!
      wrote last edited by bryn
      I am not sure this possible atm. Normally, you can find the options by creating an importer object and calling DumpTree on the Options, to see the names of the options.
      It seems though, the Solidy option is inside a group with spaces in the name ("Stereo Lithography STL"). The name of the property cannot have spaces, so it is not accessible, e.g. by writing
      importer = xcm.CreateImporterFromFile(file_name)
      importer.Options.Stereo Lithography STL.Solidify.Value = Tre
      I guess you could traverse the property group to find the child called "Solidify" and set it's value to True. We will investigate and make this option accessible for the 9.0 release.
      Regarding the actual problem, though. Can you please explain in more detail what you mean by "surface current viewer"? Maybe we can fix this issue for the upcoming 9.0 release - it seems like it may be too restrictive and would be easy to fix.
        the "Import As Solid" issue is fixed in the dev version. In 9.0, you can do this
        importer = XCoreModeling.CreateImporterFromFile(file_name)
        importer.Options.Solidify.Value = True
        entities = importer.Import(file_name)
        meanwhile, you could use this workaround
        def find_property(prop, name):
            if prop.Name == name:
                return prop
            for i in range(prop.Size):
                child = prop.Children[i]
                result = find_property(child, name)
                if result is not None:
                    return result
            return None
        solidify = find_property(importer.Options, "Solidify")
        assert solidify is not None
        solidify.Value = True
        assert len(entities) == 1 and isinstance(entities[0], xcm.Body)
        • T Offline
          T Offline
          tiwwexx
          This is great, Thank you Byrn!
          Regarding the other problem, when I have an object that is imported as a mesh grid instead of a solid body, the surface current viewer will not work. For example, I have a gradient shield that is defined as a solid object (it is a rectangular prism in the modeling tab) and a simple straight dipole that is a mesh grid (the tetrahedral like object in the modeling tab). After simulating some harmonic voltage source and going to the analysis page to check surface current density, only the gradient shield will have the surface current quiver vectors, there will be apparently no viewable surface currents on the dipole which had the actual voltage source. I hope this is an easy fix on your guys side as well!
            do you have a screenshot of the model entities (showing the explorer and 3d view)?
            it would help a lot to clarify your description. If you really have a tetrahedral mesh, does this mean you have an unstructured simulation (or is it rectilinear)? Do you get an error message (can you copy it here)?
            We can check the different model entity types, to see if something doesn't work there.
