  4. The shape of the T1 image and the shape of the electric field are different
18 Posts 2 Posters 7.6k Views 2 Watching
    what do you mean by "The T1 and the electric field seem to be in opposite directions along the x-axis"?
    • the interpolated T1 image and the E-field?
    • is the interpolated T1 image NOT shown in the same position/orientation as the original T1 image from the modeler?
    • is the original T1 image (which you imported in the modeler) aligned/shown in the same position/orientation as the model?
    It would help if you would add screenshots to your question, with explanations of what each screenshot is trying to demonstrate.
      @bryn What I mean is that the slice with index 0 in the T1 image and the slice with index 1 in the electric field are not on the same side of the head model along the x-axis. Additionally, I would like to know if it is possible to export the interpolated T1 image. I need the T1 structural image that corresponds to the simulated electric field to create a dataset.
      c2b26fe5-7cd7-465e-9e27-81b29b410516-image.png 8c9a6f68-03be-4d1c-8a88-8ce3eab8c903-image.png
        but are you using a slice field viewer to show the interpolated MRI slice? If not you basically are looking at the original MRI, with different grid and data ordering.
          @bryn I don't know how to use the slice viewer to inspect the T1 image. I just want to export it.
            I sent you code (it can also be done in GUI) above to interpolate the T1w image onto the E-field/simulation grid. If you do that you can export it in the same format as you export the E-field (not as a nii.gz file, since the simulation grid is rectilinear which is not supported by nifti files).
              #10
              @bryn Is the following code correct? I'm not sure if the input is correct.
              inputs1 = [model_to_grid_filter.Outputs[""]]
              field_data_text_exporter1 = analysis.exporters.FieldDataTextExporter(inputs=inputs1)
              field_data_text_exporter1.FileName = output_file1
              field_data_text_exporter1.UpdateAttributes()
              document.AllAlgorithms.Add(field_data_text_exporter1)
              field_data_text_exporter1.Update(overwrite=True)
                this does not include the interpolation...
                to access an output of an analysis algorithm you can use named outputs or indexed outputs, in your snippet above it may be easier to use the index '0'.
                inputs1 = [model_to_grid_filter.Outputs[0]]
                  @bryn Thank you!!! I'll give it a try!^^
                    @bryn After executing the code, an error occurred that prevented the export of the txt file.
                      looking at the error 'Unable to create destination file', I would guess you are trying to write to a directory that does not exist (yet) or without write permissions
                        However, the electric field data can be exported.
                          what does your code look like? I create the pipeline in the GUI and it seems to run fine for me (v9.0.0). The "To Python" function yields
                          # This script was auto-generated by Sim4Life version 9.0.1
                          import numpy
                          import s4l_v1.units as units
                          from s4l_v1 import ReleaseVersion
                          from s4l_v1 import Unit
                          try:
                              # Define the version to use for default values
                              ReleaseVersion.set_active(ReleaseVersion.version9_0)
                              # Creating the analysis pipeline
                              # Adding a new ModelToGridFilter
                              inputs = []
                              model_to_grid_filter = analysis.core.ModelToGridFilter(inputs=inputs)
                              model_to_grid_filter.Name = "IXI025-Guys-0852-T1"
                              model_to_grid_filter.Entity = model.AllEntities()["IXI025-Guys-0852-T1"]
                              model_to_grid_filter.UpdateAttributes()
                              document.AllAlgorithms.Add(model_to_grid_filter)
                              # Adding a new SimulationExtractor
                              simulation = document.AllSimulations["EM"]
                              # Adding a new EmSensorExtractor
                              em_sensor_extractor.FrequencySettings.ExtractedFrequency = u"All"
                              document.AllAlgorithms.Add(em_sensor_extractor)
                              # Adding a new FieldInterpolationFilter
                              inputs = [model_to_grid_filter.Outputs[0], em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]]
                              field_interpolation_filter = analysis.core.FieldInterpolationFilter(inputs=inputs)
                              field_interpolation_filter.UpdateAttributes()
                              document.AllAlgorithms.Add(field_interpolation_filter)
                              # Adding a new FieldDataTextExporter
                              inputs = [field_interpolation_filter.Outputs[""]]
                              field_data_text_exporter = analysis.exporters.FieldDataTextExporter(inputs=inputs)
                              field_data_text_exporter.FileName = u"D:\\temp\\ExportedFieldData-T1w.txt"
                              field_data_text_exporter.UpdateAttributes()
                              document.AllAlgorithms.Add(field_data_text_exporter)
                          except Exception as exc:
                              import traceback
                              traceback.print_exc()
                              # Reset active version to default
                              ReleaseVersion.reset()
                              raise(exc)
                              your code is still not using the FieldInterpolationFilter to interpolate the T1w image onto the same grid as the E-field. Note, the FieldDataTextExporter takes the output of the interpolator as input
                              • brynB bryn referenced this topic on
                              • T tbone referenced this topic on
