  4. Xtracting S11 data via python
5 Posts 2 Posters 1.7k Views 2 Watching
    Spuky
    Hi everybody,
    I am trying to extract S11 data of an EdgeSource sensor from a broadband simulation via python, however I found only the way how to extract frequency data.
    How can I access the S11 data as well? Part of my code is
    simEM_results = sim.Results()
    S11_axis = simEM_results["EdgeSource (Dipole)"]["Reflection Coefficient(f)"].Data.Axis
    S11_data = ???
    Basically I am looking for equivalent to SEMCAD X 14.8.6 XNumPy.AsArray() function.
    Thanks,
    Spuky
    • S Spuky
      Hi everybody,
      S11_data = ???
      Thanks,
      Spuky
      @spuky basically, you need to:
      1. load the data object (i.e. read data from disk and push it through the postprocessing pipeline)
      S11 = simEM_results["EdgeSource (Dipole)"]["Reflection Coefficient(f)"].Update()
      1. get the data you need from the data object
      S11_axis = S11.Data.Axis
      S11_data = S11.Data.GetComponent(0)
      Note that, once you have executed step 1, you can easily explore what the data object contains by using auto-completion in the Console environement: just type "S11" followed by a dot (.) in the Console and you can navigate its data structure.
        Spuky
        Hello Sylvain,
        Thank you for your quick answer however when I do
        The S11 is True (Boolean) and it does not contain any Data.
        Regards,
        Spuky
          my mistake... that's because Update() is returning a Boolean. This is what I meant:
          S11.Update()
            Note: I would even recommend to raise an exception if the pipeline fails to update, before continuing with the data processing. This makes the scripts easier to maintain in the long run:
            assert S11.Update(), 'Failed to update pipeline'
