Understand the h5 file structure
Analysis & Postprocessing
3
Posts
2
Posters
1.0k
Views
2
Watching
After running the simulation the results are saved on my computer as h5 file so I want to understand how the sensor readings are stored in the h5 file.
I want to extract the current density value per voxel. Is it feasible if I have the result h5 file? -
to get the current density in Python you could use a script like
import s4l_v1.document as document try: # add a SimulationExtractor for the simulation call "LF" simulation = document.AllSimulations["LF"] simulation_extractor = simulation.Results() # create an EmSensorExtractor em_sensor_extractor = simulation_extractor["Overall Field"] em_sensor_extractor.FrequencySettings.ExtractedFrequency = u"All" document.AllAlgorithms.Add(em_sensor_extractor) # update the pipeline, make sure current density is extracted em_sensor_extractor.Outputs["J(x,y,z,f0)"].Update() # get data current_density_field = em_sensor_extractor.Outputs["J(x,y,z,f0)"].Data except Exception as exc: import traceback traceback.print_exc()
