  4. A list of useful Sim4Life Python API snippets in a real project
5 Posts 3 Posters 2.0k Views 3 Watching
  • Robin WydaegheR Offline
    Robin Wydaeghe
    Hello there,
    I made a coding project where I used the Sim4Life Python API quite a bit, check it out! I figured that a list of all the places it interfaces Sim4Life would be useful to the community: https://rwydaegh.github.io/goliat/reference/useful_s4l_snippets/
    Pasting only the questions here so Google crawlers can find it, while keeping this post not too long!
    1. Application control
    How can I start the Sim4Life application programmatically?
    How can I suppress Sim4Life logging output?
    2. Project management
    How can I create a new Sim4Life project?
    How can I open an existing Sim4Life project file?
    How can I save a Sim4Life project?
    How can I close a Sim4Life project?
    How can I get the current project file path?
    How can I access all simulations in a project?
    3. Model and geometry
    How can I get all entities in the model?
    How can I get the bounding box of entities?
    How can I create geometric entities?
    How can I import models from files?
    How can I export entities to files?
    How can I transform entities (translate, rotate, scale)?
    How can I calculate distance between entities?
    How can I delete entities?
    How can I create Vec3 vectors?
    How can I identify and work with entity groups?
    How can I access child entities in a group?
    How can I decompose a transform into rotation and translation?
    4. Materials
    How can I access the material database?
    How can I link a material from the database to a simulation?
    How can I access material properties?
    How can I update material properties after frequency changes?
    5. Simulation setup
    How can I create an EM-FDTD simulation?
    How can I configure solver settings (kernel, etc.)?
    How can I set simulation time and termination criteria?
    How can I add an edge source (antenna excitation)?
    How can I add a plane wave source (far-field)?
    How can I add sensors (edge, point, far-field)?
    How can I configure automatic gridding?
    How can I configure manual gridding?
    How can I configure subgridding?
    How can I configure grid padding?
    How can I configure boundary conditions (PML)?
    How can I add voxeler settings and create voxels?
    6. Simulation execution
    How can I write the solver input file?
    How can I run a simulation locally?
    How can I run iSolve.exe manually?
    How can I submit a simulation to oSPARC cloud?
    How can I get the input file name from a simulation?
    7. Results extraction
    How can I access simulation results?
    How can I use E-field data as input to analysis algorithms?
    How can I extract SAR statistics?
    How can I extract peak SAR location details?
    How can I extract input power?
    How can I extract power balance?
    How can I extract point sensor data?
    8. Data and downloads
    How can I get available model downloads?
    How can I download a model?
    9. Analysis algorithms
    How can I add an algorithm to the document?
    How can I remove an algorithm from the document?
    How can I access algorithm outputs?
    How can I access all simulation settings?
    How can I set frequency extraction settings?
    10. Rendering and UI
    How can I set the view direction?
    How can I zoom to an entity?
    How can I capture a screenshot?
    How can I change the current UI mode?
    How can I control entity visibility?
    The introduction of the full PythonAPIReference that ships with Sim4Life v8.2+ was a big help and I invite you to look there, or to use the To Python function. The tutorials also cover a lot, but I hope that these snippets can cover some of the leftover gaps when it comes to real-world examples.
    Feel free to contact me if there are mistakes, or open an issue. Happy coding!
      This is nice. Thanks @Robin-Wydaeghe
        rtc
        Hi @Robin-Wydaeghe, any chance you would be able to make this public again? Would greatly appreciate it to learn how to best calculate distance between 2 entities.
          Robin Wydaeghe
          wrote on last edited by Robin Wydaeghe
          Hi @rtc
          The project has to undergo a temporary embargo as part of a publication which should finish hopefully in a couple months. For now, I've put the useful Sim4Life snippets in a gist here: https://gist.github.com/rwydaegh/aa87c8f76715786d99373ad9d0ba2f8b
            rtc
            thanks so much, appreciate it!
