  4. Declaring weights in simulation combiner from array changes wrong channels
2 Posts 1 Posters 936 Views 1 Watching
  • N Offline
    N Offline
    Nogniks
    wrote on last edited by Nogniks
    I want to use the Python API to generate different predefined configurations of eight channels in a multiport simulation. As a simplified example, I would like to make eight different simulation combiners, with for every nth simulation, the power of the nth channel being 1W (and all other channels 0W). I would do this using the following code:
    def multiport_SAR_export(powers, phases, config_nr):
        # Adding a new EmMultiPortSimulationCombiner
        inputs = [em_multi_port_simulation_extractor.Outputs["EM - Source 1  (pTx coil/Channel 1)"], em_multi_port_simulation_extractor.Outputs["EM - Source 2  (pTx coil/Channel 2)"], em_multi_port_simulation_extractor.Outputs["EM - Source 3  (pTx coil/Channel 3)"], em_multi_port_simulation_extractor.Outputs["EM - Source 4  (pTx coil/Channel 4)"], em_multi_port_simulation_extractor.Outputs["EM - Source 5  (pTx coil/Channel 5)"], em_multi_port_simulation_extractor.Outputs["EM - Source 6  (pTx coil/Channel 6)"], em_multi_port_simulation_extractor.Outputs["EM - Source 7  (pTx coil/Channel 7)"], em_multi_port_simulation_extractor.Outputs["EM - Source 8  (pTx coil/Channel 8)"]]
        em_multi_port_simulation_combiner = analysis.extractors.EmMultiPortSimulationCombiner(inputs=inputs)
        em_multi_port_simulation_combiner.UpdateAttributes()
        weights = em_multi_port_simulation_combiner.GetChannelWeights()
        for n, channel in enumerate(weights):
        	weights[channel] = powers[n], phases[n]
        for channel in weights:
    		em_multi_port_simulation_combiner.SetChannelWeight(channel, *weights[channel])
        document.AllAlgorithms.Add(em_multi_port_simulation_combiner)
        # Adding a new EmMultiPortSensorCombiner
        inputs = [em_multi_port_simulation_combiner.Outputs["Overall Field"]]
        em_multi_port_sensor_combiner = analysis.extractors.EmMultiPortSensorCombiner(inputs=inputs)
        em_multi_port_sensor_combiner.Name = "Overall Field (combined)"
        em_multi_port_sensor_combiner.UpdateAttributes()
        document.AllAlgorithms.Add(em_multi_port_sensor_combiner)
    configs_powers = np.identity(8)
    for config_nr in range(8):
        multiport_SAR_export(configs_powers[config_nr,:], np.zeros(8), config_nr)
    As expected, I get eight simulation combiners, in which each one has a single channel with power 1. However, it is not always the case that the nth channel has a power of 1W for the nth simulation combiner. For example, I've had a case with the following combination of simulation numbers and powered channels:
    simulation 1 = channel 1
    simulation 2 = channel 7
    simulation 3 = channel 3
    simulation 4 = channel 8
    simulation 5 = channel 2
    simulation 6 = channel 6
    simulation 7 = channel 4
    simulation 8 = channel 5
    This "remapping" is consistent throughout simulations: if I would in the next simulation try to power channels 4 and 5, in the simulation combiner channels 8 and 2 would be powered. However, after a restart of the computer (and changing a few things to the code) a new remapping has appeared:
    simulation 1 = channel 4
    simulation 2 = channel 5
    simulation 4 = channel 6
    simulation 5 = channel 1
    simulation 6 = channel 2
    simulation 7 = channel 8
    simulation 8 = channel 7
    Does anyone know what could cause those seemingly random changes in channel declarations? I've something is not clear, please ask me and I am happy to try explaining it better.
    • N Offline
      N Offline
      Nogniks
      The problem has to do with (to me) unlogical ordering of the 'weights'-dict. I have made a workaround which extracts the values from the dict in alphabetical order of the keys, which seems to work.
