  4. how to Create PolyLine using an array of points with 100 elements
2 Posts 2 Posters 1.2k Views 2 Watching
  • F Offline
    F Offline
    Farhana
    I need to create a polyLine that goes through 100 points. Is there any way that I can write the python code which uses the array of points to generate the polyLine?
    Thanks-
    Farhana
    • E Offline
      E Offline
      edopao
      yes you can.
      Use the function CreatePolyLine from the module XCoreModeling
      This function takes a list of points as input. Points need to be Vec3 objects
      smth like:
      import XCoreModeling
      from s4l_v1.model import Vec3
      #points is your array of 100 points with spatial coordinates
      points = [Vec3(p) for p in points]
      XCoreModeling.CreatePolyline(points)
