  4. who can tell me what is the wrong
3 Posts 2 Posters 851 Views 2 Watching
  • D Offline
    D Offline
    daolin_qu
    ERROR: Fatal log error: conversion of log message to UTF-16 failed.
    ERROR: Can't close HDF5 file.
    ERROR: Simulation '20HZ' failed on 2021-Apr-11 11:11:04
    ERROR: The solver process returned an error code:
      This could be due to Chinese characters in some settings or simulation names that are not handled properly. You could try to change those settings/names to use ascii characters only and see if the problem persists?
      • D Offline
        D Offline
        daolin_qu
        thank you bro,I have found what the wrong ,I have simulated too many times, causing the D drive to run out of space. I cleaned it up and the problem was solved.
