  4. Setting up voxel priorities in model
5 Posts 3 Posters 1.3k Views 3 Watching
  • B Offline
    BorKos
    wrote on last edited by BorKos
    My question is rather simple - is it possible to somehow assign the priorities (for voxeler) of different model entities in the modelling interface in a way that could then be imported into a new sim4life file (as a model import only)?
    I have a way to do that now in the voxels settings in the simulation setup under voxels properties, but I would like to take a cad model that I create and import it into different files and not have to manually set up the voxels settings in every new simulation I set up.
      snowy
      Hey,
      I am no expert, but I think you cannot connect the voxeler priorities to the cad model. But if you have already set up the simulation properties (including the voxeler priorities), you can right-click onto the simulation name --> To Python, which opens the scripter. There, you get the code for the whole simulation setup that you can simply (modify and) run and don't have to set up the settings every time.
      • B Offline
        BorKos
        That is a good point! I will try that.
        There obviously has to be a way since the VIP models work so well, but I guess this is not documented end-user functionality. :)
          Habib
          Hi @BorKos
          As @snowy mentioned, the CAD model cannot hold information about voxel priorities. This can only be done in the simulation setup. Python could be an option to keep record of the priorities and apply them to other simulations.
          • B Offline
            BorKos
            Thanks for the answer. I thought there was a way since the VIP models handle this so well, but Python should work as well.
            Or is there a way to to sort the priorities by entitiy name?
