  4. Thicken the helix wire
4 Posts 2 Posters 1.9k Views 2 Watching
    LCL
    wrote on last edited by LCL
    Hello
    I find a problem when I use the thicken wire
    I make a helix(the radius is 0.5mm and the distance is 0.45mm) and want to thicken it to 0.05mm using the thicken wire. But I find a mistake like below and there are many self-intersect surfacewire.jpg
    So I try another helix which is larger than the former one like belowwire2.jpg
    I find it worked but obviously the helix is not smooth. Is that mean the helix is constituted by many small cylinders so when I work with a small helix there will be errors like above.
    How can I deal with this problem
    Thank you so much!
    L 1 Reply Last reply
    • L LCL
      Hello
      Thank you so much!
      LCL
      • PeterStijnmanP Offline
        PeterStijnman
        Hey,
        You could try to use the solution that was posted here:
        https://forum.zmt.swiss/topic/62/creating-a-wire-from-a-line-arc/2
        This uses the python API. Maybe that works, otherwise, you could try to dive into the "xCoreModelling" library using python and try to construct a helix using that. However, that might be tricky to figure out so let me know if the above works.
        • PeterStijnmanP PeterStijnman
          Hey,
          LCL
          @PeterStijnman Thank you so much for your solution,I will try it.
