  4. Missing psSAR in SAR statistics table when using Python API
pythonsarapi
1 Posts 1 Posters 1.6k Views 1 Watching
    When using the "To-Python" script autogeneration in the Analysis for SAR Statistics evaluator, the results may miss the "Peak Spatial Average SAR" column in the table. This seems to be due to a bug in the autogeneration method, which forgets to add one line.
    Below is the autogenerated script (for the SCC3 Benchmark tutorial), with the missing line added
    import numpy
    import s4l_v1.units as units
    from s4l_v1 import Unit
    simulation = document.AllSimulations["SCC34 Benchmark Simulation"]
    em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters
    # Adding a new SarStatisticsEvaluator
    sar_statistics_evaluator = analysis.em_evaluators.SarStatisticsEvaluator(inputs=inputs)
    sar_statistics_evaluator.UpdateAttributes()
    sar_statistics_evaluator.Snapshot = u"8.35e+08"
    sar_statistics_evaluator.EnablePSAvgSar = True # <==== this line is missing when "autogenerating" the script
    sar_statistics_evaluator.StdDev = False
    sar_statistics_evaluator.TotalLossyVolume = False
    sar_statistics_evaluator.VoxelCount = False
    sar_statistics_evaluator.LossyVoxelCount = False
    document.AllAlgorithms.Add(sar_statistics_evaluator)
    # Adding a new DataTableHTMLViewer
    inputs = [sar_statistics_evaluator.Outputs["SAR Statistics"]]
    data_table_html_viewer = analysis.viewers.DataTableHTMLViewer(inputs=inputs)
    data_table_html_viewer.Visible = False
    data_table_html_viewer.UpdateAttributes()
    document.AllAlgorithms.Add(data_table_html_viewer)
