  4. Post analysis in python code
2 Posts 2 Posters 1.4k Views 2 Watching
  • F Offline
    F Offline
    Fariba_karimi
    Dear supporter,
    I run neurostimulation in Sim4LifeLight V 5.0.1.4765 and then, I plot my results by means of following code:
    #start of my code
    def AnalyzeSimulation(sim):
    import s4l_v1.analysis.neuron_evaluators
    # Create extractor for a given simulation output file
    results = sim.Results()
    inputs = []
    for sensor in results.keys():
    	if "PointSensor" in sensor:
    		sensor_extractor = results[sensor]
    		document.AllAlgorithms.Add(sensor_extractor)
    		sensor_extractor.Update()
    		inputs.append(sensor_extractor["v"])
    plot_viewer = analysis.viewers.PlotViewer(inputs=inputs)
    plot_viewer.Update()
    document.AllAlgorithms.Add(plot_viewer)
    AnalyzeSimulation(simNeuro)
    #end of my code
    I want to do some post processing on my plotted data, but unfortunately, I do not know how can I access data through python code.
    Thanks for your help.
    Fariba
      after the line sensor_extractor.Update() you can access the data using either:
      • sensor_extractor["v"].Data.GetComponent(0) (if 1D data)
      • sensor_extractor["v"].Data.Field(0) (if 3D data)
      these return the numpy array holding the raw data. Type dir(sensor_extractor["v"].Data) in the Console to get a list of available functions that can be useful for Data objects.
