  4. Using Server for Parameter Sweep
remote solverisolveparameter sweepdefault setting
9 Posts 4 Posters 4.5k Views 4 Watching
    sayimgokyar
    I'm using a client computer to prepare models and running simulations on a remote server. Results are transferred back to my local/client computer after finishing. When I tried to run a parameter sweep on a previously run simulation, unfortunately, it tries to use my local/client computer instead of the server. I realized that there is no 'default setting' for the preferred solvers. So, I wonder if I can set my default 'iSolve' as the remote one or not.
    I would be grateful if you would offer a solution for me to use the remote server as the default one for parameter sweeps.
    P.S. I tried to shut down my local ARES to disable local isolve.exe but it didn't work as expected. Also, I tried to add the path of remote 'isolve.exe' to my local ARES but it didn't work either.
    • T Offline
      T Offline
      tcs
      Hi, I have the same issue. Did you have any luck with it?
      S 1 Reply Last reply
      • T tcs
        sayimgokyar
        @tcs hi,
        Unfortunately not. Right now, there is no way to use remote computers for parameter sweep or optimization. I learned that it is in the 'to do list' of zmt. I'm waiting for the future builds to see this feature in S4L.
        • J Offline
          J Offline
          Jasper Goethals
          Hi, Is this problem solved in the V6 update?
          • J Jasper Goethals
            sayimgokyar
            @jasper-goethals
            Yes it is. Now I can use optimization and parameter sweep functions in remote sessions.
            • J Offline
              J Offline
              Jasper Goethals
              Hi, thank you. Could you point me some documentation how to select this from the sweep interface, or could you tell me how I select the server from the sweep interface? Thanks in advance.
              • J Jasper Goethals
                sayimgokyar
                wrote on last edited by sayimgokyar
                #7
                @jasper-goethals said in Using Server for Parameter Sweep:
                c
                Hello Jasper,
                Still, I cannot send my parameter sweeps from a local client to a remote server. I can run parameter sweeps by using a remote session (like rdp on windows) on the server. Previously, Workbench was not working on remote sessions, hence, it was impossible to run parameter sweeps even using a rdp type applications. Now, at least Workbench screen is working with rdp connections.
                So, still we cannot send parameter sweep iterations from a client computer to a remote server. Hence, there is nothing to select from sweep interface. You should simply open your simulation file using the server itself.
                Best,
                Sayim
                J 1 Reply Last reply
                • S sayimgokyar
                  c
                  Hello Jasper,
                  Best,
                  Sayim
                  J Offline
                  J Offline
                  Jasper Goethals
                  @sayimgokyar Thank you for the clear answer. I get it now.
                    MGo
                    Hi everyone,
                    I'm using Sim4Life and currently working with the Optimizer tool. I would like to run the optimization algorithm on a network server using ARES instead of executing it on my local machine.
                    However, I can't seem to find an option in the simulation settings that allows me to select the server as the execution target — the optimizer always defaults to running locally.
                    Is it now possible to run parameter sweeps and optimization tasks on a remote machine in the network (without using a remote desktop session)?
                    If so, how can I configure this in Sim4Life?
                    Thanks in advance!
