  4. How can I interpolate the last snapshot of data in thermal simulation
Scheduled Pinned Locked Moved Solved Python API
6 Posts 2 Posters 3.0k Views 2 Watching
    Aiping
    Z43
    I run the thermal simulation and want to interpolate only the last snapshot of data in python, how can I do that?
    Thank you
      Note: the following is in Sim4Life 3.4, I am not sure to what extent it works with older versions.
      There is an "Extract Snapshot" algorithm, which you can use to extract only the latest snapshot of your data. You can then use its output as an input for the "Interpolator" algorithm:
      You can do the same thing from Python (I used the "To-Python" tool)
      # -*- coding: utf-8 -*-
      # This script was auto-generated by Sim4Life version 3.4.2.2438
      import numpy
      import s4l_v1.units as units
      from s4l_v1 import Unit
      try:
      	ReleaseVersion.set_active(ReleaseVersion.version3_4)
      	simulation = document.AllSimulations["Heating"]
      	simulation = document.AllSimulations["Dipole"]
      	simulation_extractor_2 = simulation.Results()
      	# Adding a new ThermoSensorExtractor
      	thermo_sensor_extractor = simulation_extractor["Overall Field"]
      	document.AllAlgorithms.Add(thermo_sensor_extractor)
      	em_sensor_extractor = simulation_extractor_2["Overall Field"]
      	em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters
      	# Adding a new FieldSnapshotFilter
      	inputs = [thermo_sensor_extractor.Outputs["T(x,y,z,t)"]]
      	field_snapshot_filter = analysis.field.FieldSnapshotFilter(inputs=inputs)
      	field_snapshot_filter.Snapshot = u"1806 s"
      	field_snapshot_filter.UpdateAttributes()
      	document.AllAlgorithms.Add(field_snapshot_filter)
      	# Adding a new FieldInterpolationFilter
      	inputs = [field_snapshot_filter.Outputs["T(x,y,z,t)"], em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]]
      	field_interpolation_filter = analysis.core.FieldInterpolationFilter(inputs=inputs)
      	field_interpolation_filter.UpdateAttributes()
      	document.AllAlgorithms.Add(field_interpolation_filter)
      	# Adding a new SliceFieldViewer
      	inputs = [field_interpolation_filter.Outputs["T(x,y,z,t)"]]
      	slice_field_viewer = analysis.viewers.SliceFieldViewer(inputs=inputs)
      	slice_field_viewer.Data.Mode = slice_field_viewer.Data.Mode.enum.QuantityRealModulus
      	slice_field_viewer.Slice.Index = 41
      	slice_field_viewer.UpdateAttributes()
      	document.AllAlgorithms.Add(slice_field_viewer)
      except Exception as exc:
      	import traceback
      	traceback.print_exc(exc)
      	# Reset active version to default
      	ReleaseVersion.reset()
      	raise(exc)
      A 1 Reply Last reply
        Aiping
        Z43
        Thanks, I will try it.
          Aiping
          Z43
          @sylvain said in How can I interpolate the last snapshot of data in thermal simulation:
          Dear Sylvain,
          I tried "extract snapsho", it worked in the workbench, but in the script it doesn't work.
          Here is the error:
          Traceback (most recent call last):
          File "C:\Users\yao\Documents\Sim4Life\Python Script\Myscript\extraction_sar2T_all.py", line 185, in <module>
          field_snapshot_filter.Snapshot = u"1200 s"
          File "C:\Program Files\Sim4Life_v3.4.1.2244\s4l_v1_api\propbinders.py", line 101, in fsetter
          api_prop.set(value)
          File "C:\Program Files\Sim4Life_v3.4.1.2244\s4l_v1_api\propwrappers.py", line 306, in set
          raise ValueError("Invalid value, '{0}' not in {1}".format(inputvalue, self.enum))
          ValueError: Invalid value, '1200 s' not in None
          can you please help to have a look why is that?
          Thank you very much.
            Maybe try to add
            before selecting the snapshot.
            • S Sylvain
              import numpy
              try:
              	import traceback
              	raise(exc)
              Aiping
              Z43
              @sylvain
              Never mind, I figured it out why.
              Thanks anyway
