  4. plot a specific parameter on a surface
1 Posts 1 Posters 700 Views 1 Watching
  • F Offline
    F Offline
    Fariba_karimi
    Dear all,
    for some projects, it is valuable to be able to plot a specific parameter on a surface. For instance, consider you want to plot energy density in spherical capacitor which is proportional to square of electric field. for this purpose, you can write python code like below:
    import numpy
    import s4l_v1 as s4l
    import s4l_v1.units as units
    from s4l_v1 import Unit
    ReleaseVersion.set_active(ReleaseVersion.version5_2)
    simulation = document.AllSimulations["LF Unstructured"]
    # Adding a new ModelToGridFilter
    inputs = []
    model_to_grid_filter = analysis.core.ModelToGridFilter(inputs=inputs)
    model_to_grid_filter.Name = "desired surface"
    model_to_grid_filter.Entity = model.AllEntities()["desired surface"]
    model_to_grid_filter.MaximumEdgeLength = 0.1e-3, units.Meters
    model_to_grid_filter.UpdateAttributes()
    document.AllAlgorithms.Add(model_to_grid_filter)
    # Adding a new FieldInterpolationFilter
    inputs = [em_sensor_extractor.Outputs["EM E(x,y,z,f0)"], model_to_grid_filter.Outputs["Surface"]]
    field_interpolation_filter = analysis.core.FieldInterpolationFilter(inputs=inputs)
    field_interpolation_filter.UpdateAttributes()
    document.AllAlgorithms.Add(field_interpolation_filter)
    field = field_interpolation_filter.Outputs[0]
    field.Update()
    #get data
    data = field.Data.Field(0)
    #compute desired value
    out=data**2
    target_grid=model_to_grid_filter.Outputs[0].Data
    energy_density= s4l.analysis.core.ComplexFloatFieldData()
    energy_density.Allocate(1,target_grid.NumberOfPoints, 1)
    energy_density.Grid = target_grid
    energy_density.Quantity.Name = "out"
    energy_density.SnapshotQuantity = field.Data.SnapshotQuantity
    energy_density.Snapshots = field.Data.Snapshots
    energy_density.ValueLocation = field.Data.ValueLocation
    energy_density.SetField(0, out)
    energy_density.Check()
    source = s4l.analysis.core.TrivialProducer()
    source.SetDataObject(energy_density)
    inputs = [source.Outputs["out"]]
    surface_viewer = analysis.viewers.SurfaceViewer(inputs=inputs)
    surface_viewer.Data.Mode = surface_viewer.Data.Mode.enum.QuantityRealPart
    surface_viewer.UpdateAttributes()
    document.AllAlgorithms.Add(surface_viewer)
    surface_viewer.Update()
