  4. Creating coils via Python
pythoncoils
1 Posts 1 Posters 1.7k Views 1 Watching
    The GenericToolkit module, available from the Python API of Sim4Life, interfaces with most of the templating tools of the GUI.
    One can for example use it to interface with the Coil Template tool to generate all sorts of coils, as in the example below:
    import GenericToolkit
    import s4l_v1.document as doc
    ## Solenoid, circular
    newcoil = GenericToolkit.Create('Coil')
    newcoil.Parameters.Geometry.CoilGeometry.Spatial.Value = 1  # {0: u'Flat', 1: u'Solenoid'}
    newcoil.Parameters.Geometry.CoilGeometry.Shape.Value = 1    # {0: u'Rectangular', 1: u'Circular'}
    newcoil.Parameters.Geometry.CoilGeometry.Figure.Value = 0   # {0: u'Helix', 1: u'Parallel Circles'}
    # newcoil.Parameters.Geometry.CoilGeometry.Figure.Values    # list all available values (in the console)
    newcoil.Parameters.Geometry.CoilProperties.Radius.Value = 50
    newcoil.Parameters.Geometry.Layers.NumLayers.Value = 6
    newcoil.Parameters.Geometry.Layers.Thickness.Value = 12
    newcoil.EvaluateParameters()
    ## Solenoid, square
    newcoil.Parameters.Geometry.CoilGeometry.Shape.Value = 0    # {0: u'Rectangular', 1: u'Circular'}
    newcoil.Parameters.Geometry.CoilProperties.Width.Value = 50
    newcoil.Parameters.Geometry.CoilProperties.Length.Value = 70
    newcoil.Parameters.Geometry.Layers.NumLayers.Value = 3
    newcoil.Parameters.Geometry.Layers.Thickness.Value = 4
    ## Flat, circular
    newcoil.Parameters.Geometry.CoilGeometry.Spatial.Value = 0  # {0: u'Flat', 1: u'Solenoid'}
    newcoil.Parameters.Geometry.CoilProperties.NumTurns.Value = 10
    newcoil.Parameters.Geometry.CoilProperties.InnerRadius.Value = 25
    newcoil.Parameters.Geometry.CoilProperties.OuterRadius.Value = 45
    newcoil.Parameters.Geometry.Layers.NumLayers.Value = 1
    # Print all available properties in the Console
    print newcoil.Parameters.DumpTree()
