How to export the high quality of results images from Analysis section
I typically just take screenshots (I recommend SnagIt since it 'snaps' screenshots to subwindows (for example, just the rendering window).
Alternatively, for reproducibility, I sometimes use a script to take screenshots.
There's a third way (unfortunately not so reliable), which is to use the built in Screen shot grabber ... Go to 3D View -> Screen Capture (you need to configure it first ... I say it's unreliable because saving a particular '3D View' (Camera Settings -> Save) doesn't work well when you reimport it (views get forgotten or overwritten)
For the script I do something like this. I create a wireframe, zoom to it, and then use the following script (which you'll need to tweak via trial and error since you might get weird behavior for the color bars and ruler, axis, etc).
#Manual Record Screenshot import s4l_v1 as s4l import XCoreModeling import XRendererUI import XCoreUI bb = "CameraBoundingBox" e_cam = s4l.model.AllEntities()[bb] bb_pts = XCoreModeling.GetBoundingBox([e_cam]) oglview = XCoreUI.GetUIApp().Frame.MainView[0] oglview.ZoomTo(bb_pts[0], bb_pts[1]) x_size = bb_pts[1][0]-bb_pts[0][0] z_size = bb_pts[1][2]-bb_pts[0][2] img_dim = [x_size,z_size] screen_prefix = "Test" screen_name = "Test" XRendererUI.SaveScreenCapture(width = int(1000*img_dim[0]/img_dim[1]), height = 1000, \ transparent_background = False, output_folder=r"C:\Users\montanaro\Desktop\Screen", \ output_prefix=screen_prefix+screen_name)
