  4. Is there an equivalent of "Remove Parametrization" from the Python API?
Scheduled Pinned Locked Moved Solved Python API
pythonmodeling
3 Posts 2 Posters 2.1k Views 2 Watching
    I would like to unite a coil (created using the Template Tool) with a polyline (to close the circuit).
    The Boolean operations are not available, however, since the coil objects are locked. Removing the parametrization of the coil works in the GUI but how to do it from Python?
    • PeterStijnmanP Offline
      PeterStijnman
      No clue if you still need the answer to this, but a solution is:
      entities = model.AllEntities()
      # select the group of coils
      Coil_Group = entities['COIL 1']
      # get the entities of in the group
      Coils = Coil_Group.Entities
      # loop over the entities and set the remove only to false
      # this should be enough to use boolean operations
      for Coil in Coils:
      	Coil.ReadOnly = False
      # if you also want to remove the parameters from the coil group
      Coil_Group.Parameters.Clear()
      Cheers ^^
        Brilliant, thanks!
