  4. SetUp Field Crop Filter
python
2 Posts 2 Posters 1.5k Views 2 Watching
    snowy
    Hi Guys,
    I am currently adapting a code I've written in Sim4Life 2.3 some years ago to Sim4Life 6.0 and found out that a lot has changed in the meantime.
    How do I properly set up a Field Crop Filter (for the EMLF-Solver)?
    This is what my original code looks like and the SetInputConnection and Value commands seem to be deprecated.
    import sys, os
    import s4l_v1.analysis.core as core
    # Create extractor for a given simulation output file
    results = sim.Results()
    overall_field_sensor = results[ 'Overall Field' ]
    e_field = overall_field_sensor['EM E(x,y,z,f0)']
    # pipe the E_field through a crop filter
    crop_filter = core.FieldCropFilter()
    crop_filter.SetInputConnection(0, e_field)
    crop_filter.Update(0)
    crop_filter[0].SetValue = (63, 123, 513)  # set lower extent of crop region (in grid indexes)
    crop_filter[1].SetValue = (198, 271, 662) # set upper extent of crop region (in grid indexes)
    analysis.RegisterAlgorithm(crop_filter)
    Thanks for your help!
      In general, an easy way to create a postprocessing script is to first do it in the GUI and then use the "To-Python" function (available via right-click on the algorithm in the Explorer window).
      Here is what the auto-generated script looks like for a simple pipeline with a Crop Filter:
      	simulation = document.AllSimulations["EM"]
      	em_sensor_extractor.Normalization.Normalize = True
      	em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters
      	# Adding a new FieldCropFilter
      	field_crop_filter = analysis.core.FieldCropFilter(inputs=inputs)
      	field_crop_filter.LowerExtent = numpy.array([1, 3, 2])
      	field_crop_filter.UpperExtent = numpy.array([21, 21, 21])
      	field_crop_filter.UpdateAttributes()
      	document.AllAlgorithms.Add(field_crop_filter)
      Note fyi that you don't actually need to pass a Numpy array to UpperExtent or LowerExtent, it also works if you pass any iterable, like a list or a tuple.
