  4. how to draw exponential line
  • F Offline
    F Offline
    Farhana
    I have to draw a Vivaldi antenna, with a surface with exponentially tapered edge. If I have an exponential curve then I can draw a line along that curve to make the exponential edge. Can anyone suggest how to enter the equation of an exponential curve in sim4Life?
    SylvainS 1 Reply Last reply
    • F Farhana
      Here is a piece of code that creates a coil wrapped onto a torus, using lines defined from 3D parametric equations.
      It makes use of Law(), Curve(), CreateWireBody() and SweepAlongPath() from the XCoreModeling package.
      import numpy as np
      import XCoreModeling
      def create_toroidal_coil(R, r, m, n=1, i=1, name="Toroid"):
      	Create a spline model object with a spiral shape.
      	The shape is defined from a 3D parametric equation.
      	# equation
      	b = 2. * np.pi * float(i) / float(m)
      	x_component = "({R}-{r}*cos({b} + {n}*t)) * cos(t)".format(R=str(R), r=str(r), b=str(b), n=str(n))
      	y_component = "({R}-{r}*cos({b} + {n}*t)) * sin(t)".format(R=str(R), r=str(r), b=str(b), n=str(n))
      	z_component = "{r}*sin({b}+{n}*t)".format(r=str(r), b=str(b), n=str(n))
      	path = XCoreModeling.Law("vec({}, {}, {})".format(x_component, y_component, z_component))
      	curve = XCoreModeling.Curve(path, 0.0, 2.*np.pi)
      	# Create a spline wire body to visualize
      	wire = XCoreModeling.CreateWireBody( curve )
      	wire.Name = name
      	torus_centerline  = model.CreateCircle(model.Vec3(0,0,0), model.Vec3(0,0,1), 10)
      	torus_centerline.Name = 'Centerline'
      	torus = model.CreateSolidCylinder(model.Vec3(10,0,0),model.Vec3(10,0,0), 3)
      	torus.ApplyTransform(model.Rotation(model.Vec3(1,0,0), np.pi/2))
      	XCoreModeling.SweepAlongPath(torus, torus_centerline, make_solid=True, cut_off_end=True)
      	# Theoretical self-inductance:
      	area = np.pi * (r*1e-3)**2
      	L_theoretical = 4.0e-7 * np.pi * n * n * area/ (2.0* np.pi *R * 1e-3)
      	print(L_theoretical * 40)
      	return wire, torus
      if __name__=="__main__":
      	wire, torus = create_toroidal_coil(10,3,1, n=100)
