  4. How to change the direction(theta and phi) of the main beam of Circular Array antenna?
5 Posts 2 Posters 2.3k Views 2 Watching
    rose
    My English might be bad. Please ask me if there is my lack of explanation.
    I'm working on the tutorials on Phased Array Antenna(Rectangular). After I finished, I changed the shape type to the circular one(because of my research).
    I wanted to change the beam direction like θ=30°,Φ=45°, but I couldn't. I thought the way to do it was to set up the each phase of the elements(in my case, there are 8 elements), but it wasn't.
    Does its phase mean "phase difference when excitation is applied", right?
    My question is,
    1. Is there any way to change the beam direction?
    2. What will happen when I change the phase?
      For example, I set up each phase to 0° at first. And I rotated by 30° at each elements in the next Analysis.
      As a result, although the shape of the beam had changed, the direction hadn't changed. Why?
    Thank you!
    SylvainS 1 Reply Last reply
    • R rose
      My question is,
      Thank you!
      @rose in first approximation, the beam direction is given by the product of the radiation pattern of a single element and the "array factor" of the antenna. The array factor depends only on the relative positions of the antenna elements and on excitation applied at each element (usually only the phase).
      I would suggest you read about phased-array antennas and understand how the "array factor" AF(theta, phi) is calculated for different array geometries (starting from a linear array, then a rectangular array, then a circular array). There are plenty of books/articles on the subject.
      For example this short thesis about a circular array antenna: https://scholarworks.uttyler.edu/cgi/viewcontent.cgi?article=1005&context=ee_grad
      I hope this helps
      R 1 Reply Last reply
        rose
        Thank you for the reply.
        I understand the theory(formula) of circular array antenna. I wanted to change the beam direction like θ=30°,Φ=45°. But there wasn't any scan angle XY, there was scan angle on properties tab when I chose Rectangular though. There was just Phase Shift, but I don't know what Phase Shift mean because it's not included formula of Array Factor of Circular Array.
        How can I control the direction of the beam ?
        • SylvainS Sylvain
          I hope this helps
          rose
          @sylvain Thank you for the reply.
          • R rose
            @rose see my answer here
