  4. Automatic Coil Tuning with the MATCH-Toolbox
1 Posts 1 Posters 743 Views 1 Watching
    Michael
    Hello Everyone,
    i have recently attempted to tune and match a simple loop-coil using the MATCH-toolbox. This has worked, but i had to manually adjust the values of the capacitors.
    I have tried using the 'Initial Maching' Option to automatically create these values, but it creates a matching circuit for all four ports. So far i have not been able to force the algorith to consider certain ports as loads.
    My setup is a simple loop coil, with a total of four evenly spaced breaks, connected by wires. Three of these wires should be used as capacitors and one as the feed.
    Does anyone have any advice for this situation?
