  4. Streamline view_arbitrary plane
python
    Micol
    Could you tell me if there is a way to obtain streamline view with a plane source on an arbitrary plane (of which I know origin and normal) via a Python script?
    Thank you for your help
      Yes, this is possible, as shown in the example below.
      Note that this sort of scripts can in principle be automatically generated using the "To Python" function from the GUI (in this case by right-clicking on the Streamline Viewer). Here, however, the autogenerated script did not fully work, as it forgets a crucial Update() call before setting up the Plane Center and Normal.
      I hope this helps!
      simulation = document.AllSimulations["EM"]
      # Adding a new StreamLineViewer
      stream_line_viewer = analysis.viewers.StreamLineViewer(inputs=inputs)
      stream_line_viewer.Streamline.SeedSource = stream_line_viewer.Streamline.SeedSource.enum.PlaneSource
      stream_line_viewer.Update() # this line is needed, otherwise the next lines have no effect
      stream_line_viewer.Streamline.Plane.PlaneCenter = numpy.array([0.2, 0.05, 0.002])
      stream_line_viewer.Streamline.Plane.PlaneNormal = numpy.array([0.2, 0.5, 1.2])
      document.AllAlgorithms.Add(stream_line_viewer)
