  4. How to export voxel data using python API?
3 Posts 2 Posters 1.6k Views 2 Watching
    mingjuan
    I wonder how to export voxel data using Python API. Is there anyone who can help me? Thank you!
      wrote on last edited by montanaro
      I normally just get it from the h5 input file if you know where it is (in Acoustics it's under Meshes, then eventually in a dataset called voxels - you can use HDF5View to examine your input file).
      Some (untested) code to get you started:
      import h5py
      import s4l_v1 as s4l
      def geth5Dataset(h5f, group_name, dataset_name):
      	def find_dataset(name):
      		if dataset_name in name:
      			return name
      	with h5py.File(h5f, 'r') as f:
      		k = f[group_name].visit(find_dataset)
      		return f[group_name + '/' + k][()]
      def getVoxels(h5f):
      	return geth5Dataset(h5f, 'Meshes', 'voxels')
      sim_idx = 0 # Simulation number
      sim = s4l.document.AllSimulations[sim_idx]
      file_name = sim.GetInputFileName()
      file_path = "c:/file_path/"
      vox = getVoxels(file_path + file_name)
      M 1 Reply Last reply
      • M montanaro
        import h5py
        			return name
        def getVoxels(h5f):
        mingjuan
        @montanaro I've tried it and it worked. Thank you very much!
